Need help choosing offset and width for an 1992 r32 gtr
Hello,
I have a 1992 nissan skyline gtr with 18x8.5" on the front and 18x9.5" on the rear with unknown offsets and unknown spacers so I am running just rwd for now but I would like to run awd and I would like to get rid of the spacers because they are not hub centric so the car shakes at around 100km/hr. Hence, I would like to run 18" rims but I need help choosing an offset and rim width. I have found that I need a rim with a centerbore of 66mm but I cannot find a common response to the offset and rim width. Thanks, Justin |
Ill try and keep it simple......
A very commom size of alloy to use for the R32 GTR aswell as the 33 and 34 is a 18x9.5J For the R32 you need an offset of around 20ET (15-25 should be OK) So look for an alloy that is between 9.0J - 10.0J with an offset of 20ET. You also need to choose a correct tyre size, 255/35 or 265/35 section is the norm with the alloy sizes mentioned. I have 18x9.5J 15ET, 265/35/18 tyres fitted to my R32 GTR. Now I have the suspension/ride height very very low and have had the arches rolled/flared for the alloys to fit. There is alot of room now but I would get scrubbing if they were'nt! Its very easy to roll the lip on the arches, a garage nearby should be able to do it. It will give you an extra 20mm to play with. I also have a set of 18x9.0J 20ET, 255/35/18 tyres. These fitted perfectly with the standard arches with no rubbing. Baz |
car lowered, camber within oe spec and no modes to arches
9x18 +22 9.5x18 +22 fills it out more and more common 9.5x18 +15 protrude out pass the rear wheel arch a few mm, best used with 255/35/18 or 245/40/18(stretched look). pcd 5x114.3 hub - most aftermarket wheels are 73mm and you use a 73-66.1 hub reducer to get the right size. also as mentioned above, there is a leeway depending on width and offset. |
I run 18x9.5 ET12 and they sit perfectly in the arches. They do not protrude out of the arches. However any less offset than this and they would.
I would suggest either 9.0" or 9.5" rims if you're looking at 18" wheels. You could then run either 255 or 265 tyres. There is a chap who runs 10.5 with 275/35R18 he's not said if they rub so that's probably the limit. I'd have thought that a 275 would sit better on a 10" rim if that's any help. |
