how much boost??
well after 2 years of building the final bits are being done just haveing the turbo
fitted and its off for mapping my tuner says he will be seting full boost @ 1.5 bar but i think with this build i can get a bit more ??? what do you think? spec .. engine tomei..sump baffel " sump plates " head stud set " main stud set " head gasket set " poncams step 1 " cam wheels " fuel pump " fuel reg nissan new std crank balanced greddy oil pump " manafold " hard pipe kit acl race berings eagle h beam rods balanced je forged pistons 86.5 balanced garrett t04z rc engineering 750cc injectors os giken str twin plate clutch ported head power enterprise cam belt oil cooler apexi pfc d jetro hks intercooler hks bov tannibe exhaust blitz boost controler blitz turbo /oil/ temp/ pressure gages blitz turbo timer bee r rev limiter 8 pot brakes nismo oil filter..... your thoughts would be appreciated many thanx.... chris |
