Old 2nd October 2008, 07:41 PM   #1 (permalink)
Listerofsmeg's Avatar
Send a message via AIM to Listerofsmeg Send a message via MSN to Listerofsmeg
how best to "prime" a new turbo?
How exactly do you do this? do you fit it and turn the engine over (without firing) to push oil through it?
or do you put some oil up the oil drain to lube the bearings up first??
any other suggestions?
Ironically given that ive probably used about 8 different turbos on various cars, ive never owned a brand new one....!!
White R33 GTR
Its working!!
10.908 @ 128mph on pump fuel and full trim!
Listerofsmeg is online now   Reply With Quote
Old 2nd October 2008, 08:51 PM   #2 (permalink)
ADMINISTRATOR
Mookistar's Avatar
unplug the CAS and turn it over for 30 seconds AFAIK
mook
WANTED - TEIN FLEX for R33 GTR
FOR ALL GTR FORUM RELATED ISSUES CONTACT THE ADMIN TEAM 'MOOKISTAR' OR 'MOLEMAN'
SKYLINE FAQ'S!
Old 2nd October 2008, 08:51 PM   #3 (permalink)
yup, got my answer
think my battery would die after 30 secs though :P
White R33 GTR
Its working!!
Old 2nd October 2008, 09:15 PM   #4 (permalink)
cokey's Avatar
I primed the new turbo's by injecting best quality synthetic into the cartridge and same for the feed tube before fitting. I also span the wheels during this. it may be considered anal by some but my thinking was they would at least be lubricated whilst the oil system got round to pressurising the system. Even though there would be no boost on tickover they would still spin.I thought it would be stupid not to bearing the cost of the new turbos !
I await be-ration from all the internet experts on here.
Seemed to work fine in my opinion.
cokey
Old 2nd October 2008, 09:20 PM   #5 (permalink)
minifreak's Avatar
you could unplug the CAS and remove the plugs meaning no compression so the turbos would spin very little and due to the higher speed of the engine turning over id imagine a little more oil pressure.
just an idea
minifreak is offline   Reply With Quote
Old 2nd October 2008, 10:29 PM   #6 (permalink)
cokey's Avatar
I unplug the cas routinely when I go to the batcave and spin the motor till I have 4 bar oil pressure before I start it.
Thats because the batsignal does not go off that often up here, and it only takes a few seconds thanks to my Tomei pump.
Maybe my paranoia stems from this being the 3rd engine in my car and its special !
This compulsive behaviour may change once I fit the accusump thats in the boot ?
Cant be good to run new turbos dry out the box till the oil pump gets to pressure the system and feed them can it ?
Only my opinion though, cokey
Old 3rd October 2008, 03:31 AM   #7 (permalink)
Piggaz's Avatar
Send a message via ICQ to Piggaz Send a message via MSN to Piggaz
Plugs out, unplug CAS and crank.
Cant see there being any other way.
Piggaz is offline   Reply With Quote
Old 3rd October 2008, 05:45 AM   #8 (permalink)
ecoshardcore's Avatar
unplug cas, pull the fuel pump fuse and crank for 30 seconds. reinsert fuel pump fuse and plug cas back in.
For all your turbocharged desires!
Dealers for:
Garrett,HKS,OS Giken,Defi,Aem,ATI
Psi Supply
sales@psi-supply.com
www.psi-supply.com
Garrett GT2860-5, -7, -9 and -10 turbos instock!
TO4Z's are incoming
Click below for screaming deals
http://www.gtr.co.uk/forum/104035-80...ping-sale.html
ecoshardcore is offline   Reply With Quote
Old 3rd October 2008, 09:40 AM   #9 (permalink)
I recently changed turbos on my gtr i did the take out the fuse in the boot trick, started the car for ten seconds at a time till oil pressure light extinguished. obviously you must change the engine oil when doing turbos, well i did anyway best to prime them with fresh clean oil.
when you are happy that oil has circulated everywhere and every time you start without the fuse in the oil pressure gauge starts to read then it should be fine.
re-insert the fuse start the car let idle for 5 -10 minutes without revving once this is done you may gradually rev the car i did this and let it run for about 30 minutes and drove around for 20 minutes on light throttle.
job done now bring the turbos in gradually away you go .
turbotim1980 is offline   Reply With Quote
Old 3rd October 2008, 01:16 PM   #10 (permalink)
miragev's Avatar
cokey
i did exactily the same mate when i fitted my 2530's
better safe than sorry for the sake of 10 minutes running oil through them ..
miragev is offline   Reply With Quote
Old 3rd October 2008, 02:06 PM   #11 (permalink)
Madden's Avatar
Just unplug the Cas as that also turns the fuel system off. So the injectors wont work.
Removing the plugs will be good as that will not put any air out the exhaust to spin the turbo's.
Old 3rd October 2008, 06:25 PM   #12 (permalink)
Doh! I forgot about that
Dealers for:
Psi Supply
www.psi-supply.com
TO4Z's are incoming
Old 4th October 2008, 03:54 AM   #13 (permalink)
GT-R Glenn's Avatar
I think pretty much everything everyone has said is correct, but dont underestimate how good ball bearings are(Im assuming its a bb turbo)
Im 99.9% sure you could just stick them on the engine and start it, with it idling and let the oil find its own way to the turbo.
It would only take a fraction of a second to get oil into the cartridge.
Remember its no differerent than any other time you start it....
Except it might not have residual oil in the bearings.
But I bet it has ....
Old 4th October 2008, 07:24 AM   #14 (permalink)
minifreak's Avatar
see what your saying glenn, but im sure youll agree. for safety, it takes 2 secs to unplug the CAS and nomore than 5 mins to remove plugs.
Old 5th October 2008, 03:32 AM   #15 (permalink)
GT-R Glenn's Avatar
Yep definatley,
But, if the car sat around for 4 months without being started, it wouldnt be any different.
