Old 6th October 2008, 03:09 PM   #1 (permalink)
Peter R32's Avatar
hcr32 rb26 rwd question
Going to put the rb26 in with rb26 gearbox.
Know already what needs to be done to the gearbox and sump but still have a question about the rear driveshaft.
The hcr one will be to long I gues so hase to be modiefied, and put a gtr front on to fit the rb26 gearbox?
Or will a gtr one fit my hcr32 diff so I can take that one and only have to modify the lengt?
Hope I got the good words for everything .
cheers,
Peter R32 is offline   Reply With Quote
Old 6th October 2008, 07:10 PM   #2 (permalink)
Wanabee Kiwi's Avatar
If it's only 2wd you cannot use the GT-R gearbox as the transmission tunnel has no room for the transfer case.
As far as i know the driveshafts are all the same length throughout the whole range
Wanabee Kiwi is offline   Reply With Quote
Old 6th October 2008, 07:52 PM   #3 (permalink)
Peter R32's Avatar
No prob just weld another tunnel or adjust it a litle.
Can also chop of the piece that sticks out on the side (the 4wd system) and put a plate on it.
Old 26th October 2008, 07:12 AM   #4 (permalink)
rb30r34's Avatar
Just use an rb25det gearbox out of an r33 gts25t or an r34 gtt. They are the same gearset as the rb26 but set up as two wheel drive. No transfer case and they bolt up to the rb26 no probs
rb30r34 is offline   Reply With Quote
Old 26th October 2008, 08:32 AM   #5 (permalink)
Peter R32's Avatar
Sill have the driveschaft problem then?
If so ,ill stick with the rb26 box that one I already have.
Old 26th October 2008, 08:53 AM   #6 (permalink)
Stachi's Avatar
Use a RB25 prop shaft then?
Marc
Old 27th October 2008, 07:34 AM   #7 (permalink)
R.I.P.S NZ's Avatar
Definatly better to use the R33 RB25det box.
There's alot of mucking round to use a 4wd GTR box in a 2wd shell and the driveshaft is totally different.
You can put the RB25 yoke on the front of the 2wd driveshaft you have now and your done,
Rob
R34 GTR: Quickest street trim skyline in NZ, 9.7 @ 137 on 1st test pass, first meeting in the UK, 10.4 @ 144.
240z, WRH8.71 / 162 @ 2 bar, stock crank, full street trim
1972 240z, RIPS RB30, quickest/fastest Jap street car in NZ 8.71/162mph 2 bar, No NOS, street tyres.
e-mail rips@inspire.net.nz
www.ripsltd.com
