Old 7th October 2008, 01:53 PM   #1 (permalink)
Thinking about getting some new shoes.
Like the title says, been thinking about getting a new rim and tire setup for the R32. I've been reading and researching a lot on this forum and the general consensus is that an 18 x 9.5 with a 265/35/18 tire would work well and that a +22 offset is ideal.
So here is my dilemma. I am wanting to run the setup mentioned above. The rims that I'm looking forward to purchasing are 5Zigen FN01RC Hot Version face polish:
They come in 12, 35, and 45 offsets. I was thinking about going with the 35s and using spacers to fill out the wheel wells. Now on to my questions:
Will this offset work without spacers?
Will the tires and or rims rub against any suspension components?
I believe the stock setup on GTRs is a 30 offset. Would spacing out to a 30 offset work?
Should I just go with a spacer to make up the difference and run a 22 offset look?
Thanks in advance.
hardcoregonzo is offline   Reply With Quote
Old 7th October 2008, 02:10 PM   #2 (permalink)
nino_brown's Avatar
Just run the +12's and roll the inner arches
I hate spacers!
nino_brown is online now   Reply With Quote
Old 7th October 2008, 02:13 PM   #3 (permalink)
V1H
265/35/18 on a 9.5 wide +22 may need more camber or mods to inner liners/arches to avoid rubbing.
not sure if +35 will make the wheel sit too far in and rub, best to check one of those offset calculators (std wheel 9x18 +30).
if you use a spacer then you need approx 13mm to sit flush with wheel arch, this may mean you'll need to get longer studs, if you keep the original studs and use a thinner spacer, it might not be hubcentric.
personally, if you're in japan, i'll go with a wheel that fits without spacers.
hth
V1H is offline   Reply With Quote
