2.8 liter and GT-RS Turbos
2.8 liter engine , GT-RS Turbos.
Nissan Skyline GT-R s in the USA Blog: Turbolag - 2.8 liter , GT-RS Turbos C16 race fuel - 26/27 psi. The turbos are HKS GT-RS with strengthened actuators set at 16 psi base. The twin turbo pipe looks polished but its actually got a splitter/divider in it. The airbox looks stock, but it has an extra air feed going to it. Exhaust manifolds are N1's. Exhaust outlets are Nismo cast outlets. Exhaust is all titanium. Camshafts are fairly small. 9.1 mm and 8.9 mm of lift. 272 / 264 duration. +4 on the intake cam , 0 on the exhaust cam. The head has been ported and modified by Jeff of RB Motorsports. Hard piping. Nismo collector. Stock throttle bodies. ARC intercooler. HKS Racing BOV. Engine management is AEM with 24-1 CAS wheel. NGK #9 Racing plugs. Stock "new" coils. Stock "new" coil harness. 1000 cc injectors. Two Bosch 044 pumps in the tank. Twin -8 feeds. |
#9 (permalink) | |
I think the Nismo plenum looks pretty. The idea is good. |
a couple things...
I wonder why Nismo rates their plenum "up to" 600bhp. The divider in the twin turbo pipe...do you think that keeps the surge monster at bay? I think I may try that mod - I can't seem to be able to get my hands on a Y-pipe anyways, plus looking as stock as possible has its benefits in, uh, certain situations ![]() |
Toby, I have the twin turbo pipe mod on my car and it shuffles a little bit. When it does its not like im lacking power, it just makes a choofing noise. Give it a go. Tyndago posted a thread about a back to back comparison between a stock and a modified twin turbo pipe. From what i can remember it was worth a significant amount of horses.
#12 (permalink) |
http://http://www.gtr.co.uk/forum/84...urbo-pipe.html
Here it is. Looks like you have read it already ![]() |
#15 (permalink) |
I had a bracket made from aluminum billet, and modified (hacked away at) the stock pump cradle to hold the aluminum block bolted around the pumps. Hooked up the wires and hoses and it was all good to go!
