| Notices |
| View Poll Results: what your brake master cylinder????? | |||
| standard |
31 | 79.49% |
| N1 |
2 | 5.13% |
| some aftermarket JPN made (ex: Auto Select, etc) |
3 | 7.69% |
| some aftermarket non JPN made |
1 | 2.56% |
| some internal trick with Nissan std parts |
2 | 5.13% |
| Voters: 39. You may not vote on this poll | |||
GLOBAL AUTO JP
GTR Register Trader
There should be problem with STD brake master cylinder, are you OK (safe) with STD???
Also, what did you do with ABS??? Please list up what owner also R32, R33, and R34.
frostmotorsport
is working for a living... how boring!
Cars owned: '97 R33 GT-R, Evo 1 RS rally car, 3 Mk. II Escorts and many more!
if the front and rear calipers are the same fluid ratio as the std brakes, you shouldn't have a problem with balance.
Unless your new calipers are MASSIVELY bigger volume than the std ones, you should be good with a std master cylinder.... even 12 pot calipers should not have a greatly increased volume - but a spec sheet on them will tell you that.
GLOBAL AUTO JP
GTR Register Trader
In Japan most GT-R owners with aftermarket brake sets wouldn't run std brake master cylinder, especially people who would take their car to tracks.
STD brake master cylinder shouldn't be enough to push out enough volume for aftermarket brake sets. I don't really know volume difference between different calipers but I guess that's the point need to be checked.
tarmac terror
is feeling the Syvecs love.....
Cars owned: Genuine R32 GTR; Genuine X5 4.8iS; Replica Renault Megane 1.6
Well, not having upgraded my calipers yet I have paved the way by fitting an M57 master cylinder of an R33 (apparently the biggest std GTR size there is) and removing the ABS. I also gave all the calipers a good servicing as I found 4 siezed pistons among the 4 calipers. Brakes are MUCH more effective now.
I plan to run 6pot Wilwood FR and 4pot RR. TT
Nocturnal
GTR Register Trader
Cars owned: Widebody BNR32
I am currently testing a new set of brakes, front 6 pot and rear 6 pot... No problem at all at the track day, very balance and initial bite is great.
Standard R32 Master Cylinder with a Master Cylinder Brace. I always thought a R33 GTR master cylinder is needed as they are bigger, but it looks like the Standard R32 master cylinder is fine from what I have seen.
User Name Changed to MeisterR
GTROC Offer To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
pupsi
is RIPs BUILT TWEENIEROB INSTALLED AND MAPPED.
Cars owned: GTR R33.
I only responded to this thread because I thought it read, For all GT-R owner's with big D***s, sorry wrong thread.
On a serious note though, does changing to the bigger Nismo cylinder not sufficient enough, when changing to bigger brake's or even just changing to the Nismo without the bigger brakes, does that not see any benefit's??
#10 (permalink) | |
ChristianR
is rallying
#14 (permalink) | |
GLOBAL AUTO JP
GTR Register Trader
just using use of this place Maybe for people who is too lazy to type Basically, R33 and R34 std brembos are out of my concern.
#15 (permalink) |
Sub Boy
is a nana driver
I have F40 fronts and R33 brembos on the back with a RS260 Stagea master cyl.
The RS260 is spose to be the biggest with a little more bias to the rear, Saves having to upgrade the rears. The problem with the std master and bigger brakes on a 32, is long pedal. you might get good bite, but it is a bit spongy before then if you want to keep the ABS. Do a search on F40 brakes, Sean talks about this setup as being the go according to Mr GTR.
