Shaftless throttles for RB26DETT - Page 3 - GT-R Register - Official Nissan Skyline and GTR Owners Club forum
Old 28th October 2008, 10:29 PM   #31 (permalink)
Chris Wilson has no status.
Cars owned: 2 x Zeus sports GT race cars, Lola F3000 Mugen, R33 GTS-t with RB26 engine, knackered Daewoo Matiz :)
That sounds more like it For sure, used throttle bodies build up a deposit around the area the butterflies close, and it can be stubborn and rubber like to remove. Once removed the air flow will differ, hence idle may change if the AAC can't bring the air flow down low enough. The Nissan RB manual goes into depth about how to set up the TB's.
Old 28th October 2008, 10:35 PM   #32 (permalink)
goddard has no status.
goddard's Avatar
Cars owned: R34 Nismo GTT
Thanks to all those that have been PM'ing away.
To answer a few questions;
1. Price - I'm not sure yet as no one has looked at them in detail at AT. I have given a rough indication above of where they may fall.
2. Delivery - Again as no one has looked at them at the moment I can't give a definate answer. I have been designing a set for a Formula 3 team today, but may get a chance to look at them tomorrow and have a chat with the bosses about their priority. Fingers crossed that, because of their simplicity, it shouldn't be ages. Maybe a few weeks for a first off to test?
3. AT Power will always try to test their throttles against competitors and get flow results. They have nothing to hide in that regard, this isn't magic, everyone can see the difference in the pictures.
Stay tuned and I hope to have some more information asap
goddard is offline   Reply With Quote
Old 29th October 2008, 11:06 AM   #33 (permalink)
tarmac terror is building a track car
tarmac terror's Avatar
Cars owned: R32 GTR; E46 M3
Post DIY help!! Mapping problem??
GTR High Idle... Help
A couple of links which explain what I'm on about.
TT
Old 30th October 2008, 04:08 AM   #34 (permalink)
icydude is embracing not having a status
get these bad boys built
I will buy a set
icydude is offline   Reply With Quote
Old 30th October 2008, 05:18 AM   #35 (permalink)
Piggaz has no status.
Piggaz's Avatar
Cars owned: 97' V Spec Series 3
Send a message via MSN to Piggaz
Is fitting inlcuded in the price? Taking the plenum off is the worst job EVER!!!!!!!!!!!
Piggaz is offline   Reply With Quote
Old 3rd November 2008, 01:19 AM   #36 (permalink)
rb26r32 has no status.
rb26r32's Avatar
very intrested, would be great if these got going before i started the rebuild of the engine
rb26r32 is offline   Reply With Quote
Old 10th November 2008, 08:20 AM   #37 (permalink)
Piggaz's Avatar
Any progress with these?
Old 10th November 2008, 09:51 AM   #38 (permalink)
rbmrhd has no status.
rbmrhd's Avatar
Cars owned: 1990 BNR32
Not an engineer, but this looks like a pretty obvious modification. The only question is why hasn't anyone thought of this before?
rbmrhd is offline   Reply With Quote
Old 10th November 2008, 10:10 PM   #39 (permalink)
goddard's Avatar
Hi Guys,
Thanks for the poke. Been meaning to update this thread.
OK. I managed to do an initial design, which should fit and packadge onto the standard manifold and plenum. The idea is that the AT throttles use their own linkage, but is then linked to the GTR linkage via one of the tie rods. The other two tie rods would be reduntant, and would be removed.
Here are some renders,
The second part of the update is that AT are going to get an independant engine builder to run some flow tests on the throttles and manifold, using a 45mm DCOE made to fit onto the manifold. I calculated there is a massive 30% gain in cross sectional area from the AT throttles.
I also drew the GTR inlet port and measured the area on the computer. It comes out as 1552mm^2. Now the area of the std GTR throttles with spindle is just 1140mm^2. The 45mm AT throttle on the other hand will come out at 1500mm^2. So is nearly a perfect match area for area for the inlet port. Hopefully the flow tests will show a good improvement, looking at those numbers they should do!
Guys. I could also do with a list of people who are interested to get some numbers together. I was thinking along the lines of
Name / Car / Horsepower / What car is used for (track, drag, road etc)
If you have more than one car and would want more than one set please list them both.
Much regards!!
John.
Old 10th November 2008, 10:15 PM   #40 (permalink)
goddard's Avatar
TT
TT,
I can't comment on the mechanical ability of those people setting up their throttle bodies. One thing non of them mentioned is that there is an idle adjustment screw on each throttle body. If that is set too high then no ammount of tinkering with the linkages will get the butterflies to close. It read to me like it was more a case of "finger trouble" than there being a problem with the throttles themselves.
On AT throttles, the tight machining means there is no need for any seals, or coating.
Hope that helps,
John.
Old 10th November 2008, 10:22 PM   #41 (permalink)
rb26r32's Avatar
Car: R32 GTR
Power: 180awkw current going to 300-320awkw
Use: 90% street 10% drag
Old 10th November 2008, 10:58 PM   #42 (permalink)
GT-R Glenn has no status.
GT-R Glenn's Avatar
Cars owned: Hayabusa B310 Nissan 1980-670 hp R32 GTR-R33 GTS-Rodeo Ute-GasGAs 125 ec-Toyota Corolla-09KTM 250 exc
Eh ?
From a 10mm spindle , to no spindle ?
Old 10th November 2008, 11:05 PM   #43 (permalink)
goddard's Avatar
Sounds alot yes.
45mm dia = 1590mm^2
10mm spindle 45mm long = 450mm^2
2mm blade 45mm long = 90mm^2
GTR 1590 - 450 = 1140mm^2
AT 1590 - 90 = 1500mm^2
1500 / 1140 = 1.316 (or in other words 131.6% which is a 31.6% increase)
Old 11th November 2008, 12:33 AM   #44 (permalink)
DarkChild has no status.
DarkChild's Avatar
Cars owned: V-Spec II Nur
I'm interested but will only make a decision after more data and results are available.
Car: BNR34
Power: (Unknown) Currently having some parts fitted and mapped.
Use: Mostly Street.
DarkChild is offline   Reply With Quote
Old 11th November 2008, 04:09 AM   #45 (permalink)
Piggaz's Avatar
Car: BCNR 33
Power: 400 KW at wheels
Use: Mostly street
© 2001-2009 Cem Kocu
