Robbie, when you had the battery cover panel off, did you see any grommets thru the firewall, or are they driver's side?
29/05/09
Premium edition
GTC 76mm intakes+K&N filters
ID 1000cc injectors
Ben@GTC custom tune, 611bhp, 600lbsft
Russ Fellows zorst..
PF rotors, RS29 pads
SSP trans cooler
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
