jaycabs
is skint for a long time :-#(
make some mounts for the 6x9's using some 1/2 inch mdf using the templates u get with the speakers so the speakers dont sit in direct contact with the metals as for the obvious that the is no good flat area to mount them there .
you can use an angle grinder for the bulk of opening the holes up in the metal but be carefull . you will have to release the covering thats over the speakers thats on the inner side of the car but make sure not to brake it so for later u can put it back on so it all looks liks satndard still. theres probably other ways but thats how i done it and spend some time doing it so it looks tidy.
#5 (permalink) | |
jaycabs
simple answer is no , not with out cutting as there is not enough rooom for the magnet to go back were there metal is on the door . ive fitted 6x9's in the front but you do have to cut metal away and make a support for the speakers to stay in place . one of my previous posts i have gave some explaining about it , its a very tight fit and also depends on the different depths of the 6x9's you can get Best replacement for stock speakers?
#6 (permalink) | |
r34rtune
has no status.
I need to post pics. I'm really happy with the result.
