#226 (permalink) |
Fee Kindness
Cars owned: Impreza, R32 GTR, Porsche, Range Rover (Corsa if I have to!)
Gave the inside of the car a bit of a clean...
Cleaned, sanded, dusted, hoovered Covered most of the holes in the floor with pop rivetted aluminium patches. Have given it a quick coat of primer. Planning on spraying it matt black to see if that helps with visibility out of the rear screen...the plain aluminium fire wall caused a lot of glare. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() New wheel spacer arrived and is on as well, but haven't tested it yet.
#227 (permalink) |
Mookistar
is nearly up to 20,000 posts
Site Admin.
Cars owned: Mookra and R33 GTR
one of my staff has just signed up for club class in his 3 door cossie
looking good Fee! mook
Support the forum by Supporting our Sponsors. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Please note, I cannot help you with GTROC membership enquiries.
#229 (permalink) |
Mookistar
Site Admin.
yeah Ronnie. He's a good lad, he's really looking forward to it!
mook
#230 (permalink) |
wardy88
is rb30 s14a
Cars owned: 32 GTR
looking good dude
dont you think it feels smaller inside with it been black ? did you rattle can it all also what sealant did you use around the ally rear firewall ? and have you relocated the attesa ecu and other gizmos from under the parcel shelf wardy
#231 (permalink) |
Adam Kindness
is phu phu phu
the OE structure/parcel shelf is still there, with the attessa (or is it hicas) ECU under it. The amp was junked ages ago
Sealant is a fire proof sealant...cant r'ber the name but you can get similar stuff in the likes of B&Q. Basically a fireproof sikaflex.
#232 (permalink) |
Adam Kindness
is phu phu phu
sprayed the floor and firewall matt black. Will do the rear 1/4 insides next.
![]() ![]() Tidied up the cage where the door bars were welded and just primed. ![]() ![]() ![]()
#234 (permalink) |
Adam Kindness
is phu phu phu
give Plastics4Performance a tinkle and sweet talk a discount out of them.
Our door windows are thicker than the rear screen and 1/4's to help keep them shut in the door seals.
#236 (permalink) |
Adam Kindness
is phu phu phu
its a matt black, the pics were taken when it was wet.
Should start popping seats and shit back in today. Still waiting for new battery cage so will hang fire with pas seat.
#237 (permalink) |
Fee Kindness
Floor is all sprayed now and everything (nearly everything...still waiting for the new battery cage) is back in.
Did a bit of rewiring...cleaned up/relocated/cut out some stuff to make it a bit neater. Sprayed the seat rails as well, as they were a bit rusty. ![]() ![]() ![]() ![]() ![]() ![]() A few from before it was sprayed Not too sure about the blue gear surround....that was Adam's idea :lol: Any idea what this bit is? Found it to the left of the steering column. Thought I would check before pulling it out :lol: ![]()
#239 (permalink) |
Adam Kindness
is phu phu phu
small update and some Q's
Have another ECU as a loan and it seems to fire up the pumps fine. So will pop our map on it this week and hopefully get the car out on track at the weekend to blast off some cobwebs (fee and the car :P ) Time to change fluids too.... Here are the fluids I currently use.... Front Diff: Silkoline BOA 80W-90 EP Rear Diff: Silkoline BOA 90 LS Transfer Box: ATF DII (dont have II in the garage but plenty of III, will that be fine?) Gearbox: RedLine Heavy Shockproof
#240 (permalink) |
muzzer2002
is is skint after buying bits
Cars owned: r33 gtr
h adam am glad it worked and you dont have the headache of trying to go through the wiring loom etc
was good yapping to you
