GT-R Register - Official Nissan Skyline and GTR Owners Club forum - View Single Post - Final parts list from the R33 GTR i broke :)
Old 17th June 2009, 02:50 PM   #1 (permalink)
Madden
Madden has no status.
Madden's Avatar
Cars owned: R32 gtr 1991
Right just gone and made a list of all the parts i have left from the 1996 r33 gtr i broke a while ago.
The car had cover 59000 miles and was in midnight purple.
This is all i have left so no what you see is what i have.
Front Subframe with steering rack, bottom arms and powersteering pipe work. £200 for the lot or i can spilt it all up.
Rear subframe with all suspension arms, driveshafts, hicas rack and hubs £300 for the lot or can split. Might even strip the subframe and remove all the bushes so it is ready for someone to polybush.?
Passanger side door compelt with handle,window and controls, door card. Everything still attached but can split £100
Start motor and wiring loom £100
Coil pack loom. £50
4wd pump and piper work £150
4wd resisvior and pipes from boot £30
Full a/c system. Rad/condensor, pump, fan, pipe work. Will split £offers
A/C climate controller ( bit that sits in the dash) £40
Hicas ecu £20
Full lock set with orginal GTR key bar the boot lock £100
Little ignition barrel light. WORKING £10
Front wiper motor £20
Windscreen washer tank with both pumps £20
Header tank £10
Metal fuel pump cover for boot £5
Full fuel pump and levae sensor. As is comes out the tank £20
Upper gear stick rubber gaitor and plate £5
Intercooler mesh for front bumper £10
Scuttle panel £20
Rear bumper bar with number plate lights £10
Rear bumer £40
Front arch liners ( rear sections only ) £10
Rear lights complelt £80
Full car wiring loom including relays and fuse boxes £100 Can cut sections out if you need plugs or just seperate relays
Dash clocks/ speedo cluster. Lugs have snapped off both all guages still work it anyone needs any. £40
Afms standard. One is cracked where it bolts to the air box but still works. £50 for both
Rear speaker covers £10
Air bag £20
Steering wheel £20
Wiper stalk and light stalk switchs £20
Hazard and rear heater screen switchs £10
Dash vents. Top ones that blow onto the screen £10
Electric ariel. £5
Front bumper indicator surrounds £20
Ash tray £5
Carbon canistor and bracker £10
Clear side repeators £10
Sub gauges from center consul. £30
Boost gauge sensor £5
Climate control sensor from center consul £5
Front section of side skirts £20 for both slight clip damage
Rear parcel shelf vents £5
Front wiper motor relay £5
Bonnet hinges £20
Boot hinges with dampers £20
Boot fuse box and relays £20
Bonnet catch and cable £20
Battery earth £5
Horns £5
Stanard boost soloniod £5
Battery clamp £10
I am open to offers on everything or it will all go on ebay and down the skip.
JOB LOT AVAILABLE DAVE W CHEAP CHEAP
Madden is online now   Reply With Quote
