Aerial for my 32. - GT-R Register - Official Nissan Skyline and GTR Owners Club forum
Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > Audio & Security (ICE)
Old 20th February 2009, 07:08 PM   #1 (permalink)
dean j is i need of more money! cars too slow!
Aerial for my 32.
I need the radio on my car now, but aint got a clue where to get it from.
Where has everyone fitted them on their 32's???
Dean j
dean j is offline   Reply With Quote
Old 21st February 2009, 08:45 PM   #2 (permalink)
brett21 is birthdaying his GTR
brett21's Avatar
Cars owned: Skyline GTR R32
Send a message via MSN to brett21
Its in the Windscreen man, Mine works perfect.
brett21 is offline   Reply With Quote
Old 22nd February 2009, 12:14 AM   #3 (permalink)
cheers mate
You know what wire im looking for, or has it already got the aerial jack on it for it?
Old 22nd February 2009, 12:54 AM   #4 (permalink)
infamous_t is r32skylineclub.com
infamous_t's Avatar
Its in the mess of wires where the stereo would get power, you may need a converter for the aerial plug, as i know this is the case for us Aussies
Old 23rd February 2009, 01:47 PM   #5 (permalink)
Cris is slightly rippled with a flat underside
Cris's Avatar
I think that there's two antenna, one in the windscreen one in the rear screen. The connector is a funny little two pin thing. I think it's called diversity. You can get adapters to connect them to normal connectors. I may have a picture at home. I'll try to remember to have a look tonight.
Cris is online now   Reply With Quote
Old 23rd February 2009, 06:32 PM   #6 (permalink)
Well, i found the 2 pin connector, and i got the adapter for the aerial, but its just crap reception! Any way to make it better?
Old 24th February 2009, 09:32 AM   #7 (permalink)
Cris's Avatar
My guess would be that the antenna it's connected to is knackered somehow. Either find the problem and fix it or try plugging the adapter in the other way round. You might have to remove the tab on the connector to make this possible.
I'd get a meter and test for continuity between one pole (pin) and each antenna. If one pin/antenna is open circuit then you have your culprit. If they are both OK then swapping the pins round (after removing the tab as mentioned above) won't help. I suppose then I'd start looking for bad earths or test the radio to make sure it's OK.
NB I'm assuming that you using a known good UK radio?
Old 24th February 2009, 04:02 PM   #8 (permalink)
I'll try these suggestions mate when i got a moment.
I've got an Alpine head unit. New and from the uk, so its gotta be something you've suggested mate
Thanks mate. I'll let you know how i get on
Old 27th February 2009, 12:22 PM   #9 (permalink)
mambastu is redundant :(
mambastu's Avatar
Cars owned: R32GTR and RS13 RB25DETT
32's also have an aerial amplifier at the rear of the car which you need to connect your radios antennae-out too which is why your receptions crap at the moment. You'll find the wire you need to connect it to behind the radio.
Stu
R32 GTR - Godzirra
Twin turbo RB25'd 200SX RS13 - 405bhp and 348lbs ft on 15psi
mambastu is offline   Reply With Quote
© 2001-2009 Cem Kocu
