Oil in my radiator???.... R33 GTR - GT-R Register - Official Nissan Skyline and GTR Owners Club forum
Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > Nissan Skyline > Maintenance
Notices
Old 31st March 2009, 01:33 AM   #1 (permalink)
tom9999 is unaware they can edit their status
Hey guys,
I have oil in my radiator, ive done a flush, and its still there. Also the coolant is boiling but my temp gauge is not showning its overheating.
Had a full rebuild about 8 months ago. HKS 2530 turbos {23psi} MLS 5 layer head gasket the car was pinging up high then i stop driving hard (to get it fixed). then a few weeks later found oil in my radiator
Head gasket or block???
tom9999 is offline   Reply With Quote
Old 31st March 2009, 01:39 AM   #2 (permalink)
jaycabs is skint for a long time :-#(
jaycabs's Avatar
Send a message via Yahoo to jaycabs
i had this a while back and it turned out to be a crack in the head.
so was a new head that i had to get.
jaycabs is offline   Reply With Quote
Old 31st March 2009, 01:41 AM   #3 (permalink)
yeah i hoping its not the block. its being overheating a bit so warped head or cracked.. Can you pressure test the cooling system to see if it leaks to confirm its a head gasket????
Old 31st March 2009, 01:52 AM   #4 (permalink)
jaycabs's Avatar
if you pressure test the coolant then unless it leaks externaly then you wont know if its the head gasket or cracked head.
is your coolant in your radiator gone like a milk shake sludge ? and it comes back straight away after flushing the coolant and your oil levels go down quickly after a short drive ?
Old 31st March 2009, 01:54 AM   #5 (permalink)
is your coolant in your radiator gone like a milk shake sludge ? and it comes back straight away after flushing the coolant and your oil levels go down quickly after a short drive ?[/QUOTE]
yeah thats pretty much it and a overheating problem???
Old 31st March 2009, 01:54 AM   #6 (permalink)
jaycabs's Avatar
its rare for the head gasket to go on GTR's
Old 31st March 2009, 01:56 AM   #7 (permalink)
yeah very true. just hoping its not the block,, has ive just spent heaps on a big end bearing. anyway to tell its a cracked or warped head??
Old 31st March 2009, 01:57 AM   #8 (permalink)
jaycabs's Avatar
you need to get it taken in to tuner ( a good one ) on a flat bed trailer .
unless your a competent mechanic and can take the head of your self and strip it down and get a replacement head ?
Old 31st March 2009, 01:58 AM   #9 (permalink)
jaycabs's Avatar
theres no proper way besides taken the head off but you have the tell tale signs of a cracked head but you realy need to get a good tuner to inspect it even though its not cheap
Old 3rd April 2011, 08:37 AM   #10 (permalink)
TEN57 is wanting a new paint job for Xmas
I have just fixed the same problem (oil in the coolant) in my R32 GTR. What was happening with mine was carrosion had caused a small hole in the ballance chamber at the end where coolant air bleed screw is. Under boost it would drive oily air into the coolant.
What also happens is was also dropping small amounts of coolant into No1 cylinder. The easy way to test if this is your problem is to remove all your spark plugs and pressurise your radiator over night. Next morning wind over the engine and see if water vapour comes out of no 1 cylinder. If it does you might have the same issue as I did.
TEN57 is offline   Reply With Quote
Old 15th April 2011, 03:35 AM   #11 (permalink)
jasaircraft is building heat
jasaircraft's Avatar
Hi could you please tell us more clearly where the bleeder screw is?
jasaircraft is offline   Reply With Quote
Old 15th April 2011, 09:51 AM   #12 (permalink)
markpriorgts-t is R33 GTR
markpriorgts-t's Avatar
Cars owned: R33 GTR
markpriorgts-t is offline   Reply With Quote
Old 15th April 2011, 03:18 PM   #13 (permalink)
very graphic...heheh thanks
Old 16th April 2011, 08:03 AM   #14 (permalink)
Thumbs up
Yep, that's the one
Old 19th April 2011, 03:37 PM   #15 (permalink)
godzirra is unaware they can edit their status
Originally Posted by markpriorgts-t View Post
What does it mean if when I take this screw off nothing comes out??
Already filled the rad up and heated up the engine but when I took off this screw it was dry as a desert??
godzirra is offline   Reply With Quote
© 2001-2013 Cem Kocu
demoMedia
