Ferodo DS2500, Is Front & Rear fitment a BAD idea? - Page 3 - GT-R Register - Official Nissan Skyline and GTR Owners Club forum
Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > Nissan Skyline > Maintenance
Notices
Old 1st July 2003, 12:07 PM   #31 (permalink)
Peter is unaware they can edit their status
Peter's Avatar
Cars owned: E320 CDi
Gaz,
No, I haven't cos I always use axle stands (cough. cough).... Seriously though, I do use them when a wheel or wheels are off for any length of time or if I'm likely to have to use force with anything but, if I'm honest, I don't use them when working on my brakes. Bad habit I guess as of course they should be used.
Stop showing off Jason.
Peter.
Old 1st July 2003, 12:27 PM   #32 (permalink)
JasonO is absent.
JasonO's Avatar
Cars owned: R33GTS25T
Send a message via ICQ to JasonO Send a message via MSN to JasonO
I'm such a big poncy tart I just can't help it
JasonO is offline   Reply With Quote
Old 1st July 2003, 12:31 PM   #33 (permalink)
Gazmo1 is considering his next move.
Gazmo1's Avatar
Cars owned: Other Peoples!
Jason,
Have you got pink axle stands then ?
Gaz.
Gazmo1 is offline   Reply With Quote
Old 1st July 2003, 12:33 PM   #34 (permalink)
JasonO is absent.
JasonO's Avatar
No, But I've got pink bits I like to protect
Old 2nd July 2003, 10:08 AM   #35 (permalink)
R33GTS25t is unaware they can edit their status
R33GTS25t's Avatar
Cars owned: R33 GTS25t
Mine used to be red but are Pink somehow!?!?
P.S, Thanks to Abbey my new pads arrived this morning, less than 24 hours after orderinf them, Ill look forward to taking the car out tonight once there fitted!
R33GTS25t is offline   Reply With Quote
Old 2nd July 2003, 11:32 AM   #36 (permalink)
Gazmo1's Avatar
If you don't use it for a week you will find that they will turn from red back to pink.
I usually find that over use makes mine go red.
Gaz
Old 2nd July 2003, 06:55 PM   #37 (permalink)
R33GTS25t's Avatar
Changings Pads
Could someone please tell me how on earth I get the rear calipers off, there are 2 places where I can use a phillips screwdriver, 4 places where I can use the wrence and get them undone and anoother 2 places where i need to use a bigger socket to get the screws out, I would of thought its the biggest socket but I cant get mine in there!!
Help as the car is on the Jack at the moment,
Old 2nd July 2003, 09:18 PM   #38 (permalink)
JasonO is absent.
JasonO's Avatar
The caliper doesn't need to come off, remove the retainer wire spring from the pins, then pull the pins through the caliper.
Very similar to the fronts.
Old 3rd July 2003, 08:19 AM   #39 (permalink)
R33GTS25t's Avatar
Right gotya, Ill give it another go tonight, I thought that would of been the most likely case but they just didnt seem to want to budge, ill try a bit harder tonight ;0)
Old 3rd July 2003, 09:26 AM   #40 (permalink)
JasonO is absent.
JasonO's Avatar
Once you've got the little wire retainer spring out of the pins, put a screw driver in them and give them a couple of turns, then grip the head with your pliers and press the anti-rattle spring in towards the pads with one hand, then pull.
You've got a PM with my phone number if you get stuck
Old 3rd July 2003, 05:27 PM   #41 (permalink)
Rich J is unaware they can edit their status
Rich J's Avatar
Cars owned: X-Type
Just wait till you try and get there front and rear discs off, such a pain unless u have such a simple device
Rich J is offline   Reply With Quote
Old 3rd July 2003, 06:09 PM   #42 (permalink)
JasonO is absent.
JasonO's Avatar
He doesn't need to remove the disks
.......but I've never had any problems getting reluctant ones to move, eventually they all sucumb to the the power of a hacksaw, chisel and big hammer.....
Bigger the job, bigger the hammer
Old 3rd July 2003, 09:47 PM   #43 (permalink)
Rich J's Avatar
Cars owned: X-Type
Yeah i know mate, just mentioned seeing as we were on the brake subject.
Can remember when i tried to get the rear discs off when i was doing the brembo upgrade at the rear, hammer, kicking it from behind, all sorts of things! In the end i gave up and got the missus to ring are good friend Rod and he explained all! All that was needed was a bolt to put through the thread area in the discs face and then pull of the hub, simple as that!
Same goes for the front aswell, total mare but as with anything always easy when u know how or have the tools!
Old 4th July 2003, 12:05 AM   #44 (permalink)
JasonO is absent.
JasonO's Avatar
Sure, using the jack bolt is a clever enough little trick, but not all disks are created equal, and you only notice they were £10 cheaper when you want to get them off and they don't have any jack screw holes.
My method, although brutal, is very quick.......Cut about 3/4" through the disk with your hacksaw (it's cast steel and cuts really easy) then place your cold chisel into the cut, and wallop (technical measure of applied force) it with your big hammer, the disk splits in two, and you'll make the pub before last shout
Old 4th July 2003, 06:46 AM   #45 (permalink)
Rich J's Avatar
Cars owned: X-Type
How the hell u come across that method mate, lol
© 2001-2013 Cem Kocu
demoMedia
