WoREoD
has no status.
The Clonking Dinner Plate Noise!
As other people have mentioned they might have a similar noise / problem I though it might be worth starting a separate topic, so…..
The Clonking Dinner Plate noise! What are the symptoms? 1) It comes from the rear axle area and usually seems to be on the nearside (see below). 2) Its doesn’t really sound like two dinner plates rattling in the boot, its more like two very large china meat servers – or an exhaust rattling cos one if its rubber loops has fallen off (that dates me!) 3) It happens mainly at speeds of up to 40mph on bumpy roads and can be reproduced on the same road at will. 4) It happens in Auto or manual, usually at a cruising speed. 5) It also happens in all three suspension settings. What else? 1) Driving with the left foot on the brake pedal seems to make it not occur. 2) I’m beginning to suspect that the “nearside” aspect is actually induced by the camber of the road. First clue from this was the HPC technician who said he heard it on the offside a couple of times. Whats does the HPC say? 1) They spent a day and half on this and everyone agreed its not the gearbox. They did numerous test runs, with and without the lower panel and with and without the boot mats and insulation, even to the point of getting the apprentice technician to ride in the boot! 2) The took off the pads, calipers, wheel hubs and checked every suspension bolt and fitting they could see. 3) They found the rear fog light mount was loose (all four bolts) but that didn’t cure it. 4) Nissan technical also got them to tighten up the shoes in the handbrake assembly. But its still there! I’ve looked at the similar topic on NAGTROC and a couple of people on there have described similar. However that topic seemed to go off on to all sorts of rattles so its difficult to sort through the possible causes. This is not a trim rattle! My guess now is that its in the rear axle somewhere, but its not a limited slip diff clonk cos I know what that sounds like. GTR-SpecV said “that is prop shaft noise from front flywheel to rear gearbox”. I think that’s possible but why is it definitely at the rear of the car? I’d like to know if anyone else has the same symptoms so as to get an idea of how widespread this is. My HPC and its technician have been brilliant about trying to find it but Id still love to track it down for a fix…… I have to drive below 50 sometimes…..
RSPaul
has no status.
Cars owned: Audi RS4
Yes - I definitely have this exact noise!
Pi$$ing me off, as the computer also crashes/freezes every time I use the car, so no music/radio to turn up to drown-out the boot full of crockery!
Zed Ed
is lovin RE070s at 1310 fitted
GTROC Board Member
Cars owned: R35 GTR - DMG Premium
I can't place this on mine, but I'll keep an ear open
My car generally makes sounds like Van Halen.
stealth
is is pleased theVW camper is gone
Through the Night
Location: somewhere over the rainbow ( not far from Jeff )
Cars owned: GTR 35 & Renault Traffic Camper
Mine used to stick when it was new and not engage reverse ,then when it did it shot back a bit with a massive clunk noise .I used to get a few rattles here and there ,they have all gone now and reverse is sweet.Just get some miles on the cars and they will most likely settle down.
paul__k
has no status.
My 2 guesses based on the noise is not there when braking are:
1. Multi plate 1.5 way LSDs are notorious for noise at low speed tight turns and also up to about 50mph. The way the car is run in and the type of oil can also have an affect. 2. Pad rattle in the calipers. No problems here as far as I can tell but happy to bring mine round for a comparison. Paul
R35 Black Black |
Zed Ed
GTROC Board Member
yep, I've heard this now
corrugated concrete floor in a local car park brought it on bit like a rampant morris dancer
thoob
has no status.
Cars owned: NISSAN GT-R R35 Ti, NISSAN PATHFINDER, 997 911 2S, FIAT 500
I think the clatter might be the central jack point resonating on the rear diff, if you look under the car from the back, in the centre at the front of the carbon panel there is a metal dome, this panel/metal dome has movement in it.
Naranja
has no status.
Me too. I've also got the one from the front but this is deffo brake pad rattle, I recognise it from years of Jap superbikes, does disappear under light pressure on the brake pedal. Nothing to worry about anyway.
#12 (permalink) |
WoREoD
has no status.
May not be anything to worry about but after 850 miles in five days its driving me round the bend........... Given that it occurs in every 40 or less speed limit zone (and there are lots of those round here) its spoiling the car for me.......
#14 (permalink) |
Robbie J
is now happy as I've got a new house at last
Moderator
Cars owned: GTR R35 and 350z (R33s Gone)
mine sounds like 2 tin foil plates rubbing...
I'm a Mod, not sure that's a good thing R35 arrived in June 08 |
