Step by step guide to fitting Zele 4 light kit, with colour pictures! - GT-R Register - Official Nissan Skyline and GTR Owners Club forum
Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > Nissan GT-R > R35 - "How to" and DIY guides
Notices
Old 31st May 2009, 08:02 PM   #1 (permalink)
charles charlie is making R35 door mirrors fold automatically...
Single Product Trader
charles charlie's Avatar
Okay folks, I've taken some snaps to show how to fit your own Zele 4 light kit.
Tools required : 1 x flat head screwdriver (approx 5 mm width)
Time to install : Expert 10 mins, Cack-handed idiot 10 mins.........
1. Open your boot.
2. The central plastic cover at the rear of the boot has 4 plugs with loops on them, and a smaller central one without a loop.
Picture shows red circled large plugs, yellow shows central small one.
3. Each plug has 2 slots on the side into which a screwdriver fits.
3. Use a small screwdriver and pop it into each plug and twist. This causes the top of the plug to pop up. Just pull them out one by one.
4. When you've got all 5 out, the top of the plastic cover is held on the metalwork with simple clips. Just pull the cover out from the bottom first then put you fingers under top part and pop the cover upwards.
5. Lift the cover out of your boot.
6. On both sides of this cover there are 2 carpet like flaps which you can just put your hand under and the connectors are just there, attached to the rear metal.
7. Just unplug those and plug in the Zele kit.
8. I attached the short cable on the left, then ran the longer wire thru the holes in the rear metalwork (to save using tape) and across to the Right hand side.
9. The connectors have a clip on top which needs to be depressed before you can unplug them.
10 Attach the Zele box with some velcro/sticky pads, flick the switch to the 4 light marker and ALWAYS check it works before putting everything back together. When reassembling, start by putting the clips on the uppermost part of the cover in first.
11. When putting the plugs back in you'll find it easier to pull out the centre pin of the plugs (see below), then just pop the plugs back in once you've got the plastic cover back in place.
And voila!
4 lights on braking, yummy!
29/05/09
Premium edition
GTC 76mm intakes+K&N filters
ID 1000cc injectors
Ben@GTC custom tune, 611bhp, 600lbsft
Russ Fellows zorst..
PF rotors, RS29 pads
SSP trans cooler
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
Old 31st May 2009, 08:21 PM   #2 (permalink)
guycuthbert is animating data :)
guycuthbert's Avatar
Cars owned: R35 GTR Premium Gun Metallic
Nice work CC - very clear instructions. Very useful
guycuthbert is offline   Reply With Quote
Old 31st May 2009, 08:27 PM   #3 (permalink)
Robbie J is feeling we need summer
Moderator
Robbie J's Avatar
Cars owned: GTR R35 and 350z (R33s Gone)
good lad :-)
Robbie J is offline   Reply With Quote
Old 31st May 2009, 08:27 PM   #4 (permalink)
Zed Ed is elsewhere, mostly
Zed Ed's Avatar
Cars owned: Litchfield BRZ. Legacy diesel
Originally Posted by charles charlie View Post
Time to install : Cack-handed idiot 10 mins.........
Thanks for thinking of me, mate
Zed Ed is offline   Reply With Quote
Old 31st May 2009, 08:51 PM   #5 (permalink)
ramsub is unaware they can edit their status
Cars owned: R35 GTR - UMS Premium Edition
Can someone make this a sticky before we lose it. Good work
ramsub is offline   Reply With Quote
Old 31st May 2009, 08:58 PM   #6 (permalink)
You're all very welcome fellas. I'm feeling kinda guilty for not installing my reverse camera myself and sharing the install with you all, so this is going a little towards making amends!
BTW, it only took me about 10 mins to pop out and takes those piccies so it really is that easy and fast.
The only hard bit is disconnecting the connectors. The clip on top of them is very stiff and a PITA!
29/05/09
Premium edition
ID 1000cc injectors
SSP trans cooler
Old 31st May 2009, 09:27 PM   #7 (permalink)
maxxwaxx is unaware they can edit their status
maxxwaxx's Avatar
Top man, thanks im always crap at things like this, now i just need to know where to buy the kit from
maxxwaxx is offline   Reply With Quote
Old 31st May 2009, 09:29 PM   #8 (permalink)
Moderator
Robbie J's Avatar
matty32 from newera, that's where most people do
pm him
Old 1st June 2009, 07:05 AM   #9 (permalink)
Yakozan is unaware they can edit their status
Yakozan's Avatar
Cars owned: Mazda RX-7 -94, Nissan R35 -09
Do this kit light up the wing brake light even when not braking as discussed in the other thread? There was some talk about wiring it in differently to make it work like the USDM models or something.
Yakozan is offline   Reply With Quote
Old 1st June 2009, 02:12 PM   #10 (permalink)
Wired correctly (i.e. as shipped) it will not light up the wing... the only change is that all 4 lights are on when headlights are on. Inside lights still light brighter (together with wing) on braking. See the NewEra website for pictures that illustrate this behaviour...
Old 1st June 2009, 09:20 PM   #11 (permalink)
Yakozan's Avatar
good info
Only 10 days left untill delivery
Old 1st June 2009, 09:26 PM   #12 (permalink)
matty32 is Hipo34 sold to new owner :-(
GTR Register Trader
matty32's Avatar
Yeah as above
Well 28 kits this month
2 now left in stock
Hurry hurry hurry
New Products from Top Secret arriving R32/33/34/35
VISIT OUR WEBSITES!!!!
Japan Office Tel -
Calls charged at UK National Rate): 0207-193-3979.
Mobile ( Japan ): +81- (0) 90-4133-3825
Fax ( Japan ): +81-(0) 47-307-4678
matty32 is online now   Reply With Quote
Old 1st June 2009, 11:43 PM   #13 (permalink)
professor matt is missing the old gtr.co.uk
GTR Register Trader
professor matt's Avatar
Cars owned: R35 GTR BLACK EDITION R34 GTR V-SPEC/TURBOCHARGED 5 & 3 SERIES BMW
ok matty hook me up pm me the details
FASTEST STOCK TURBO GT-R IN EUROPE 10.44@135mph
size="5">Scotlands only GT-R specialist
professor matt is offline   Reply With Quote
Old 4th June 2009, 09:25 AM   #14 (permalink)
ianmartin is unaware they can edit their status
Excellent, thank you. The connectors were fiddly. The clear strips on the rear side panels always were reflectors not indicators on UK spec cars.
ianmartin is offline   Reply With Quote
Old 14th June 2009, 06:44 PM   #15 (permalink)
atcler is unaware they can edit their status
Cars owned: Audi S5
excellent guide!
Thank you charles c
May I take your guide and post it in our germans GT-R Forum? That would help them also, because the next 10 tail light sets are hopefully arriving soon.
Regards Alex
atcler is offline   Reply With Quote
© 2001-2013 Cem Kocu
demoMedia
