#16 (permalink) |
Robbie J
is now happy as I've got a new house at last
Moderator
Cars owned: GTR R35 and 350z (R33s Gone)
there was a solenoid fix with the early cars, yours might just need this?
speak to middlehurst as they have done one I think
I'm a Mod, not sure that's a good thing R35 arrived in June 08 |
#17 (permalink) | |
Benji Linney GTC
is thinking about R35 cams
#18 (permalink) | |
wheely
has no status.
#20 (permalink) | |
wheely
has no status.
never had high temps on the transmission oil,so fingers crossed ![]()
#21 (permalink) | |
wheely
has no status.
#22 (permalink) |
mindlessoath
is Elite
there are lots of fixes for this. please call dodson motorsports in NZ and south side performance in usa. they both create fixes for the GTR trans and have fixed many of them sofar. most of the problems are solinoids which you can probably clean out, some have flushed the fluids some have taken appart the trans and cleaned it out (you have to put it back a certain way). some problems are seals that break.
if its a first gear issue then the only choice right now is PPG first gear replacement, of which has sofar worked, but i dunno to what extent since no one has pushed them yet, but they have fixed alot of peoples issues sofar. most of the first gear issues are due to excessive launch control on all gt-r's that dont have the upgraded launch control. SpeedForSale.com - Toyota Supra Turbo, 2009-2010 Nissan GT-R, and Mazda RX7 service, cars, and parts for sale. sells this ppg gearset. its pretty cheap too, however not easy to install and requires someone who has docmented the trans well and knows the in's and outs and has the special tooling. in any case you guys should run transmission coolers if you dont want any troubles. the main cause of these problems is heat and launch control in general (not that there isnt other causes). most of you with serise 2 cars have launch control version2 which will have less problems with launching. also fluid changes should be changed out often if using the stock fluid. there is a temp change guide that tells you when its been in an unsafe temp zone and would require a fluid change within a certain milage or something (i forget). the only aftermarket fluid i know as of right now is willall fluid. its much better in every respect and will protect the gears better and keep things a few degree's cooler. things will be smoother and less noise. for those of you that have broken the stock clutchs there are replacements from south side performance and they have upgrade clutch packs for 700hp for those upgrading to something like gt570 kits or aftermarket turbo's. these are easy to install and just need a consult3 to calibrate. ssp also have solid transmission mounts for those looking for reduce wheel hop. those are really harsh and only for those who are probably going to be racing full time or drag racing. these paired with a good suspension coilover system should reduce alot of wheel hop (then again who would mod the gt-r right?).
#23 (permalink) |
R35-395
has no status.
Cars owned: GT3 RS
If you can pull the codes from the car i can quite happily tell you what is wrong and how it fix it.
Your car sounds like it's either a selenoid or clutch pack seal issue,i am guessing the latter. Don't sweat it, the gearbox is a easy fix. Shoot me a PM if you need a hand.
#24 (permalink) | |
bhp
is not torque
Cars owned: Evo 8
#27 (permalink) |
Robbie J
Moderator
series 2 cars have a cooling duct under the gearbox, does it do anything?
R
#29 (permalink) | |
Robbie J
Moderator
#30 (permalink) | |
infamous_t
is r32skylineclub.com
A few threads on SAU on the subject.
