Marko R1
is happy to have his old GTR back!
Cars owned: no.60/100 Australian Delivered R32 GTR
Hi guys,
I've had a few members ask me about the progress on my rb26/30 build for my R32GTR on skylinesaustralia.com & gtr.co.uk so i thought i'd add this thread (i apologise if you already seen this on sau). The car was collecting dust for over 6 months & now ive ressurected my GODZILLA with almost 1000km on the clock. Here are my specs: nissan rb30 block RB26 with extensive head porting match ported exhaust manifolds Garrett low mount -10's (combined rating @ 920hp) RIPS custom sump RIPS diff adapter plate RIPS oil pick up RIPS inspired modified catch can (return to sump) JUN crank collar ACL race bearing set Cometic head gasket Mahle piston & ring set Argo rods Camtech/Kelford billet cams Performance valve springs ARP main/head studs N1 oil/water pump HKS intercooler Sard fpr Bosch 044 lift pump with 2 external Bosch 044's & surge tank PFI dual entry fuel rail (to accommodate larger 14mm entry injectors) Delphi Rochester 1000cc injectors Ross Metal Jacket harmonic balancer OS Giken cam gears Jim Berry 4000lbs single plate race clutch (the twin & triple plate was doing my head in) Nismo engine/gearbox mount kit (good timing whilst the engine was out) Blue silicone heater/intercooler/radiator hose kit (good timing whilst the engine was out) 52mm dual core alloy radiator Power FC My run-in tune results came to 270.9awkw @ 6500rpm on 10psi (cams are still set @ 0). My goal was to crack over 400awkw with strong midrange delivery, after i do my run-in km's with higher rev limit, boost & set cams im sure this will be achievable Rob @ RIPS was a great help, he said that he almost ran out of memory on his pc from my emails If you have any q's im more than happy to answer them & help as much as i can. regards, Marko. p.s. how do i attach my dyno graph to this thread?
GTR-Dreamer
is a married man
Cars owned: Peugeot 106, Opel Corsa, Nissan Micra K12
Go to TinyPic - Free Image Hosting, Photo Sharing & Video Hosting and upload your picture.
#6 (permalink) | |
Marko R1
the cams are still set at 0degrees & it sounds very lumpy...cant wait for final tune, i like it when the car rumbles & rocks ![]()
Marko R1
i have a stack of pics as i was doing the r&r - where do i start with the pics
![]() if there is anything in particular u want to see let me know ![]()
Marko R1
it drives very well - rev limit is set @ 5000rpm so its kinda like driving a truck where i need to change gears very quickly.
even on 10psi it starts to spool quite hard around 3000+rpm & the extra 400cc has really made the world of difference. i had -10's (hks gtrs setup) on my previous rb26 & that was painful IMO, boost took too long (not with the rb30 though )my engine builder thinks i can get final tune done @ 1500km, my tuner wants me to wait till i get to 5000km (im getting it done @ 1500km, its killing me)
#12 (permalink) |
Marko R1
Hi guys,
Final tune is done on 98 pump!Refer to attached graph, it made @ 23psi: 405awkw (i.e. 550awhp) 930nm (i.e. 686ft-lbs) 445rwkw (i.e. 605rwhp) To put this into perspective, my previous rb26 on the same dyno & turbo's made 750nm. Rev limit is set at 9000rpm although the above figures are based on 8500rpm. It drives like an absolute weapon & what a difference the extra capacity makes, it really is phenomenal! My tuner’s comments: "you have the best combo for the street, the average torque increase is HUGE & will feel like an rb26 with 480awkw" "wait till you drive it, it will be completely different to any gtr" The car was squirming from left/right on the dyno, the reason is due to torque steer which my tuner has only seen on 1 other gtr with an OS Giken 3.0ltr with T51R & made 480awkw. We were going to go to 24psi but my actuators wouldn’t allow this as they are set @ 0.7bar, he suggested at this boost level it will make 415awkw. currently @ 23psi he said it is very safe for hot days & has purposely ran it a bit richer. My next step (if I want more power) is to run E85 which is a new pump fuel which was realeased here in Aust not long ago (approx. 106ron), upgrade to 1600cc injectors & run 1.2-1.5bar actuators. This will give me an average gain of 50awkw (i.e. over 450awkw) & over 1000nm. My tuner was very happy with the results considering the engine ran stock valves, intake plenum & throttle bodies. ![]()
#14 (permalink) |
Marko R1
it pulls like a train - rb26 simply does not compare.
gtr's should have rb30's from the factory, maybe the reason why the r35 now has a 3.8ltr
