jaycabs
is skint for a long time :-#(
ignition timing hot or cold ?
could some one please remind me for the setting of the ignition timing as recently i had taken the cam pulley cover off to paint it so have knocked the ignition timing out a small amount .
i thought i read some were a while ago that it was set at 20 deg when warmed up ? is that right or wrong ? just that i know as the car goes through its warm up process from cold the ignition timing does change . i have tried a search but not revealed any thing about temperature within the first 6 pages of the search. cheers any one
frostmotorsport
is working for a living... how boring!
Cars owned: '97 R33 GT-R, Evo 1 RS rally car, 3 Mk. II Escorts and many more!
yup - always when up to operating temp. Also, the loop wire is notoriously unreliable - my turner has a custom ignition lead that goes between the #1 coil and the #1 plug - so he can plug the timing light onto this HT lead and get a true reading. I must get around to making myself one!
#5 (permalink) | |
jaycabs
frostmotorsport
so.... firstly I meant tuner not turner - doh!
Also, I still assume you need to set the base timing - i.e. position the CAS, which would require a timing light - as the PFC only know's what you've told it.
#7 (permalink) | |
jaycabs
it should only be marginally out , shouldnt it ? it only looks like its a few degrees advanced more than before from a general look shortly after start up of the engine .
frostmotorsport
a visual is ok to start the engine, but GTR's are a bit "sensitive" to timing, and if your engine is tuned for more boost/power then I'd definately check base timing with a light. I'd be worried that while those 2 degrees may not do any harm a low revs/off boost, at WOT and full boost and extra 2 degrees could be the difference between having some fun and detting your engine to death!
#9 (permalink) | |
jaycabs
wanted to know though would taking the breather system of the rocker covers and going to a new catch tank venting to atmosphere plus removing the aircon system and going to a 120mm thick intercooler from a standard size one , alter the tickover ? just since ive done all that and removed and put back the cas , no matter how much i try to set the ignition timing to 20 degrees the engine's tickover just wont balance as its a little up and down ![]()
jaycabs
tried putting a timing gun on it today and o know i got it some were near the 20 deg but with the revs fluctuating its to hard to say what actual figure .
also tried using a ht lead to get the reading but strangely i couldnt get any reading using my draper timing gun ![]() i did read about the loop at the back of the engine as a pick up but also read that its quite unreliable so on the wiring going to coil pack no'1 i pulled back some of the outer black protective coating and were there is the 1 white thick wire and 2 thinner black wires ,i put the inductive pickup on the white wire as that gave the same reading as the 2 black wires together but not all 3 wires together would give a reading. ![]() was hoping it would smooth things out a little but all the changes i made obvioulsy was too much , well just have to wait to the next time it goes to RK , ages and ages and ages lol
jaycabs
curious question , on the search i found mixed info about the timing marks on the crank pulley
on my pulley there are 7 marks and on one post some showed the timing had to be set on around the first 2 marks from the left but on other post ive read the 5th mark from the left ![]() could some one clear that up for me please ? isnt it the 5th from the left being 20 deg as its 0 - 5 - 10 - 15 - 20 - 25 - 30
#12 (permalink) | |
pupsi
is RIPs BUILT TWEENIEROB INSTALLED AND MAPPED.
Cars owned: GTR R33.
Hi,
yes your absolutely correct. Starting from the 1st mark, 0, it then goes up in increments of 5, so yes the 5th mark would be 20 degrees. Your spot on. Pupsi. Quote:
#15 (permalink) | |
jaycabs
these SKYLINE GTR R32 R33 R34 TURBO ELBOW - DOWNPIPE GASKET on eBay (end time 27-Jul-10 20:05:49 BST) ? been a while since ive taken the top pipes off wouldnt removing the aicon and having the twin turbo pipe with baffle and the larger intercooler plus putting the oil breather on to atmosphere from both rocker covers cause that bad idle ??? especially the oil breather as that changes the air going in to the engine ( more clean ) and would have thought changes air pressures going in too as the left inlet back to the engine from the left rocker ive blocked off and the right one that normally goes back into the rubber piping thats joined to the rear turbo ive blocked off too . ????? weird thing is if you put it in 1st gear as the cars off the floor when the engine is running as the wheels are turning it hold the rpm fine on its own basically idles ok in gear
