#76 (permalink) | |
waltong
is back on the road!
Cars owned: R35, Alfa Mito. Previous: RS4, STI.
#77 (permalink) |
sam elassar
has no status.
Cars owned: subaru 99, evo7, evo8, evo9, evo8m, gtr r35, x5
this is going in circles, i am really sorry to hear about your engine alex but you cant expect nissan to fix it under warranty ? come on lets be serious here mate you have been in the game for long enough to know the score
did you not have an oil pump failure with the r34 as well due to oil pump failure which is a bit common on the earlier models? my take on tuning in general is if you are going to modify your car then you have to be able to fix it when 5H1T hits the fan. you most definitely have had a bearing issue and that is due to failure of the oil film between the rods and crank. oil pump failure obviously will cause that very quickly, as my evo engine suffered at 12000rpm couple of years ago!! or oil quality deteriorating due to few reasons 1- heat from sustained hi speed, i know it is difficult to look at oil temp while doing 300km/h 2- map running too rich or too lean, too rich will also dilute the oil with fuel etc etc. easy way of finding out is getting the oil tested and see if it has broken down due to heat or contaminants like metal particles or fuel were you runing full exhuast or just Y pipe? what was the afr at the top end, any EGT testing?
#78 (permalink) |
EvolutionVI
is modding the GTR all day long
GTR abuser
Cars owned: 600+PS Evo 6 TME + Evo 9 Wagon + Evo X & GTR soon
@Sam: In germany there is a few Stock GTR´s having the same problems.....even Nissan owned Demo cars out of the first batch.........like mine,all cars that have broken are out of the first european cars......
My oil was good,the mapping is good,no knocking,no melted piston,no broken sparkplug.....we dont have a "it was tuned and broke because of this" case here.....it broke because of a bad working part in the oilpressuresystem.....as all the athers.... PS: Its more cars then you think,not just 1 or 2... ![]()
_____________________________________________ Official member of the 200mph club.... |
#79 (permalink) |
Martin Donnon
is head of research
Cars owned: R35 GTR
Hi there guys, we dont post here much but some of you might know who we are - Willall Racing the company that does a lot of research on lubricants, coolers, parts design etc for the R35. We have something to add here -
When removing the sump (oil pan) off our GTR for initial design of our WR35OP High Volume oil pan we found that the original mesh in the oil pickup was over 50% blocked by the factory gasket compount sealant used to hold the original sump in place. Some GTRs have too much gasket material applied, which can come off upon installation at the factory, block the oil pickup and eventually starve the bottom end. Here is the picture proof - ![]() This is one reason we suggest GTR owners buy our WR35OP...it gives them/their workshop a chance to have a look at the oil pickup, which may save them thousands in the long run. Note we also use O-Ring seals for the new sump to stop this ever occurring in the future ![]()
#81 (permalink) |
sam elassar
has no status.
alex, can i get a sample of the oil ?
it is very interesting what you say martin but should not that have an effect on oil pressure?
#82 (permalink) |
gtr R33 lee
has no status.
Cars owned: 1000 BHP GTR R33, FERRARI 456, 348, 3X R34,4X R33,1X R32, FORD F150 LGHTNING x2, CL55K X3,E55K X3, PORSCHE 996 X2, SUPRA TT
Im shocked!
#83 (permalink) |
Martin Donnon
is head of research
Cars owned: R35 GTR
We do plenty of analysis on R35 engine oil....it was all part of our development program for our own WR35MO. At 100C the factory oil has less than 8cSt of viscosity and film strength to stop metal on metal contact at the bearing face. To give you an example of how different that is to our specification we have 15cSt, which in laymans terms is a ton more film strength.....and we do it for a very good reason!
Now take a low film strength oil that has shown - in our testing - to make bearing metal in a hard driven VR38DETT then shut the supply volume down somewhat. At 300km/h the last thing a driver will be looking for is flickers in the oil pressure gauge. Demand to have a look at your oil pickup....unless they have already cleaned it. Another 'telltale' is to look at the factory oil pan and look for missing/broken off squashed bits of silicone on the inside edge of the pan (internal edge). They all only end up in one place ![]()
#84 (permalink) | |
gtr R33 lee
has no status.
#85 (permalink) |
kismetcapitan
is like trees in November...
Toluene Junkie
to get 25 centistokes@100 degrees in the VR38, what engine oil are you using?
There are only three true sports: mountain climbing, motor racing, and bullfighting. Everything else is merely a game. |
#86 (permalink) | |
sam elassar
has no status.
what does everyones oil presure at idle, 5000revs and 7000revs for example as obvioulsy oil pressure goes up with revs it will be more pronouced at higher revs
#87 (permalink) |
Martin Donnon
is head of research
Cars owned: R35 GTR
Add to that some GTRs are seeing up to 4% fuel dilution in the oil (they run very rich standard) which has shown (in the opinion of Blackstone laboratories in the US) to drop effective viscosity of the factory brew closer to 0w-20. Hope that helps.
#88 (permalink) | |
IRISH
has no status.
#89 (permalink) | |
Martin Donnon
is head of research
Cars owned: R35 GTR
#90 (permalink) | |
clint thrust
is hating every car he sits in!
Cars owned: The BEST colour GT-R
![]() You should be banned off here you PITA. First it's WOHOO I'm getting a GT-R then it BOOO they are crap and will depreciate so fast you'll have to pay someone to take it away. THEN, it's WAHAAY pat me on the back I've re-ordered, aren't I clever. THEN 5 minutes after you have it you sell it and your straight back on slagging off this fantastic car. Nobody has had a warranty claim yet on an unmolested car. We'll see what's what then. As for running costs WTF?. Why even buy it!. I really hope they cough up and get this guys car fixed but you are a pariah on this site.
