Uprated DBA4000 slotted Discs R32 R33 R34 - GT-R Register - Official Nissan Skyline and GTR Owners Club forum
Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > For Sale & Wanted > Private: For Sale - PARTS ONLY
Old 9th February 2010, 02:12 PM   #1 (permalink)
godzilladom is making you an offer you can't refuse
godzilladom's Avatar
Cars owned: Top Secret R32 GTR
I have one set for Standard R32 GTR - RRP£330 - going for £270.
I also have one larger set to fit R33/R34 GTR (brembos) obviously if you have an R32 with Brembos then you need these - RRP£390+ - going for £300.
FREE DELIVERY
DBA’s unique directional wiper slot design limits the possibility of glazing your brake pads and allows for better ‘pad-bite’ under extreme braking. The wiper slot design constantly improves the disc pad friction face by wiping away the impurities, gases and resins from the friction material.
All DBA 4000 slotted series rotors feature the DBA directional wiper slot design, i.e. Left-handed and Right-handed directional slotting.
Thermo-Graphic markings are placed on the outer edge of each DBA 4000 series disc rotors (see images) and used to monitor the core temperatures achieved during braking application. The markings change color as the rotor heats up to alert the driver to rotor temperatures that exceed optimum levels.
Initial
Color
When rotor
exceeds this
temperature...
The color will change to...
green
458°C
white
orange
550°C
yellow
red
630°C
white
''Kangaroo Paw'' (image 2) is a patented, high-tech disc rotor ventilation system designed and manufactured in Australia by Disc Brakes Australia and available on rotors for select applications. "Kangaroo Paw" technology delivers significantly improved braking performance. Even under extreme braking conditions. Kangaroo Paw rotor designs run cooler, are stronger, and outperform traditional straight-vane disc rotors.
The ''Kangaroo Paw'' design features a series of 144 diamond- and tear drop-shaped pillars and columns individually spaced between the rotor faces.
This system provides two key advantages.
First, is the ability to cool the rotor faster than ever before. As the disc rotor rotates, aerodynamic turbulence around the individual pillars and columns is generated, increasing the force of hot air out from within the internal areas of the rotor.
Second is increased dimensional stability across the disc rotor directly achieved by the individually spaced pillars and columns.
These advantages increase the disc rotor's efficiency by as much as 20% when compared to conventional rotor designs. A 20% increase in disc rotor efficiency directly translates to reduced brake operating temperatures, brake fade, disc rotor stresses, disc thickness variation, run-out and shudder.
godzilladom is offline   Reply With Quote
Old 9th February 2010, 08:23 PM   #2 (permalink)
dave100 is getting the car ready for the modball!
dave100's Avatar
Cars owned: GTR R33
are these front and rear or fronts only?
dave100 is offline   Reply With Quote
Old 12th February 2010, 03:03 PM   #3 (permalink)
discs
Fronts only.
Old 12th February 2010, 11:38 PM   #4 (permalink)
This is a proper bargain.
I bought both these Full price 2 months ago.
Someone can make an offer if they wanna collect or meet halfway etc...
DJ
Old 17th February 2010, 01:37 PM   #5 (permalink)
DJ
PM replied to.
Really need these gone if there's any offers dwindling
Old 19th February 2010, 12:00 PM   #6 (permalink)
Been offered £270 to collect the R33GTR discs - not sure who that was - will now accept - so pls re PM me
Old 19th February 2010, 10:00 PM   #7 (permalink)
R33 Discs SOLD
Old 28th February 2010, 09:53 AM   #8 (permalink)
R32GTR Discs still available - open to sensible offers
Old 1st March 2010, 12:28 PM   #9 (permalink)
RIGHT! These are going CHEAP!!!! I need the dolla for some paint work- so grab a bargain
© 2001-2009 Cem Kocu
