BNR32 fast road project from Austria - Page 14 - GT-R Register - Official Nissan Skyline and GTR Owners Club forum
Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > Nissan Skyline > Projects
Notices
Old 30th November 2010, 09:17 AM   #196 (permalink)
Austrian GTR is finally enjoying his GTR again
Austrian GTR's Avatar
Cars owned: Golf IV TDi-PD, R32 GTR
Originally Posted by infamous_t View Post
So much engine bay space!!!
Damn you
Haha
Okay it's not so much more space, but it still makes things a little easier and cleaner
I'm also getting the used Koyo Rad from Harry (Lamb) which is slightly thicker than the standard one and with all the ps lines removed now I can keep my electric fans due to the gained space between rad and engine...
...else I'd need to buy new blowing type fans as with my current ones it was already pretty tight when they were attached to the standard rad.
Austrian GTR is offline   Reply With Quote
Old 30th November 2010, 10:21 AM   #197 (permalink)
Cris is slightly rippled with a flat underside
Cris's Avatar
Originally Posted by Austrian GTR View Post
Hi Buddy,
I know there are similar ones available from Driftworks for half the price of the KTS ones...
...talked to Miguel about KTS Japan and he ensured me they supply good quality
Just bought them as the inner bearing of the left upper arm got knackerd so it's pretty loose. Thought when I have to change it, I go for the adjustable route as on the one hand I can slightly change my camber and on the other hand I suppose it's more rigid with ball bearings instead of the standard rubber bearings...
Guess I'll know more after the next season with a few trackdays. Hope they'll last, as they were a bit expensive for just running them for only one season and then bining them
Cheers,
Leo
Leo,
I have some similar items and I've found two things which might be helpful:
1) They will unscrew themselves very quickly so make sure you use loctite (or similar thread glue)
2) They wear out quite quickly. From what I have seen there is a twisting force along the linkage. On the normal item I think the rubber bush takes the twist. On these the body of the linkage takes the strain. So far mine have been OK for 2+ years but I don't do many miles. I saw a product being developed in Australia which allows for the twist. I think if mine break I will be swapping for this design.
Simon found mine needed freeing up this year. A strip and rebuild did the trick. He suggested checking them every year. If you don't drive in bad weather you might not have a problem.
Look forward to hearing what you say about the PS removal.
Old 30th November 2010, 10:42 AM   #198 (permalink)
fourtoes is milk monitor
fourtoes's Avatar
If all else fails I will have some nice fixed Cusco ones that will be up for sale soon as i wanted all Ikeya Formula items on my car. The quality is just as good though.
bob
Like us on Facebook ZEALOU5 turning cars into heroes.
ZEALOU5
Contact: Bobby Proctor
Mobile: 07970699470
Website:
Email:
Old 30th November 2010, 12:28 PM   #199 (permalink)
Thanks for the heads-up guys
Just hope they will last until I can afford the whole Ikeya Formula stuff like you have Bobster
Chris, that makes myself a little worried now
Do they really unscrew themselves??? How can you use loctite to secure them when you have to adjust them first and shouldn't move them afterwards again as then the prior alignment would be useless???
Do they really wear that quick??? Damn, if I had known that before I'd have chosen another route
Have you got any link to the Aussie product???
For corrosion I thought I'd coat them with grease or wax or something after I got them properly adjusted...
Cheers,
Leo
Old 1st December 2010, 12:50 AM   #200 (permalink)
infamous_t's Avatar
About AU$600 Unique Autosports - Performance Car Sales - Parts & Tuning.....
A few threads about them on aus300zx.com & skylinesaustralia.com if you want to read up on them.
Old 1st December 2010, 06:04 AM   #201 (permalink)
Thanks mate
Old 15th December 2010, 04:04 PM   #202 (permalink)
godzilladom is making you an offer you can't refuse
godzilladom's Avatar
Cars owned: Top Secret R32 GTR
Originally Posted by jdmchrist View Post
i just want to tell you that dry ice help to remove the sound deadener but its not an easy job , the soundener just broke into larger pieces. i see that we have the same plan for our interior except that i will be fitting a cusco rollcage keep the picture coming!
I've heard -
"soak it in petrol, helps deactivate the sticky stuff"
"use a paint stripping gun heat it right up then peel it off"
"heat gun/blowtorch to soften it. Did the Capri in just under half a day this way"
"C02 fire extinguisher! It will break off in massive bits then white sprit to get rid of any mess."
"2nd that! Cooling is the best way, as it makes it come of in big chunks, without leaving glue and other residue as heat does... Also, it doesn't make scratches in your floor, so it's shit easy to prepare it for paint
As a Fire Extuingisher service technician I have done this in several cars, and believe me, it works. I would guess getting a lot of dry ice makes the job even easier though, as you can have it in a bag and move it around. The extuingisher get's emptied quite fast, and isn't very precise."
Dry Ice is a bit expensive is it not? how much would 20lbs cost
godzilladom is offline   Reply With Quote
Old 15th December 2010, 06:36 PM   #203 (permalink)
jdmchrist is wtb other parts!!
Cars owned: r32gtr
it has cost me 40$ canadian i think and i did some scratch on the floor when i have remove all the sticky sh** but i have smoothed everything nice and clean
jdmchrist is offline   Reply With Quote
Old 15th December 2010, 11:18 PM   #204 (permalink)
Miguel - Newera is surrounded by GT-R's.
GTR Register Trader
Miguel - Newera's Avatar
Cars owned: Techno Pro AE86, 280 bhp E30 M3, 500 bhp Knight Sports RX-7, Prelude S BB6-2010 Ebisu Endurance Champion. RC51 VTR SP2 - Tuned.
No need for dry ice/ Just wait for the coldest aub zero weather, don your thermal underwear and take to the sound deadening with a hammer. It'll come off in large chunks - easy
Matty 32 is Newera's GTR Register Official Trader. PM him for your inquiries on tuning & cosmetic parts.
Miguel - Newera is offline   Reply With Quote
Old 16th December 2010, 07:12 AM   #205 (permalink)
syclone is now diffusered.
syclone's Avatar
Cars owned: 2001 R34 GT-R, 2011 R35 GT-R
with the current temps here, no need to wait any longer...
syclone is offline   Reply With Quote
Old 2nd January 2011, 05:48 PM   #206 (permalink)
nismoboy is Tap Snap or Nap. Vale Tudo Submission Squad
nismoboy's Avatar
Cars owned: R32 GTR Project, Yamaha R1, R6 & Suzuki Hayabusa.
subscribed good work m8 loving the build good effort keep the pics coming bud
nismoboy is offline   Reply With Quote
Old 17th January 2011, 12:10 PM   #207 (permalink)
turbojerry is turbocharged
turbojerry's Avatar
Cars owned: BNR32
Thinking about doing the same mod on my car What size is the scoop and where did you by yours from? Clean looking car by the way!
turbojerry is offline   Reply With Quote
Old 17th January 2011, 12:36 PM   #208 (permalink)
Thanks mate
I'd need to measure it next time I'm in my garage as I don't have the measurements in my head tho...
...I bought it on flea bay UK, was around 30 or 40 Euros when I remember right
Old 12th March 2011, 06:46 PM   #209 (permalink)
Thought it's about time to do a little update, unfortunately not very much happened lately as it was always way too cold here and my motivation was hardly present
But as it's getting a lot warmer now I started work on my GTR again today and I hope tomorrow I'll finally have finished removing the stupid sound deadening
In the meantime I received a lot of nice parts from Miguel
Nismo Super Copper Mix Twin Competition + alignment tool, Nismo engine, gearbox and steering mounts, Nismo braided clutch line, reinforced Nismo clutch padel bracket...
...HKS GT Extension kit, HKS oil restrictors, also got my Driftworks steering spacer thanks to Bobster,...
...Tomei Poncams Type A and Tomei oil sump baffle
Now I'm just waiting to get my new Garret -9's
Old 12th March 2011, 06:58 PM   #210 (permalink)
Also bought some LED lights in Xenon white for my dash (as it was always pretty dark in the night)
And that's how it's looking now
© 2001-2013 Cem Kocu
demoMedia
You Rated this Thread:
