#333 (permalink) | |
Austrian GTR
is finally enjoying his GTR again
Cars owned: Golf IV TDi-PD, R32 GTR
Thanks guys
![]() Quote:
Cheers, Leo
#334 (permalink) |
Austrian GTR
Last weekend I continued work on my engine bay and took car of some small rusty spots before they get worse...
... used a brass wire brush to get rid of all the brown stuff and used some sanding paper afterwards before I applied 2 layers of 2K epoxy ground ![]() ![]() ![]() Also removed some spot welded plates that are no longer needed. You can also see where I made up a hole for my custom cold air supply (will get up more pics of this as soon as it's finised) ![]() The worst rusty areas were under the bonnet and door hinges ![]() ![]() ![]() It looked like the old Nissan sealant that was applied around the hinges wasn't really sealing properly anymore so some water got between the hinges and the chassis and started rusting. I'll use some new sealant once I put them back on and paint them afterwards. When the bottom door hinges are reinstalled, the top ones will get the same treatment. Cheers, Leo
#335 (permalink) |
Miguel - Newera
is surrounded by GT-R's.
GTR Register Trader
Cars owned: Techno Pro AE86, 280 bhp E30 M3, 500 bhp Knight Sports RX-7, Prelude S BB6-2010 Ebisu Endurance Champion. RC51 VTR SP2 - Tuned.
Your new Koyo rad, Nismo injectors and Greddy pulley kit will all be on their way tommorow morning, buddy.
Was hoping you'd get back on the road soon, but looks to me as if you're about to repaint the engine bay. You don't do things by halves!
Matty 32 is Newera's GTR Register Official Trader. PM him for your inquiries on tuning & cosmetic parts.
#336 (permalink) | |
Austrian GTR
![]() Also managed to get my hands on a second hand set of PS lines from Abbey in the UK, so now I really have all parts together and my engine will get back in soon ![]() I'm afarid it will take me at least another month until it's completely finished (especially as I'm on holiday for a week in Croatia with my missus in two weeks) but it's fine. And the next season I can enjoy right from the start ![]() Yep repainting the engine bay (at least partly) is on my schedule too ![]() Cheers, Leo
#337 (permalink) |
Austrian GTR
At Aki's advice I got my self some braided turbo oil and water feed line from Hose Solutions in the UK (thanks for the link Bobster
![]() ... unfortunately they came without fitting instructions and so I have no idea how they should be fitted, especially as one of the hoses has a banjp on each side ![]() Anyone any ideas where which hose should go??? Cheers, Leo
#338 (permalink) |
gijsje
is working on the car
i also have the complete kit but it did not fit very good
One bend is wrong and one coupling was wrong I still need to take pictures and send it to them. My engine is still on a stand so it will be easy to do but i have to find the time ![]()
#339 (permalink) | |
Austrian GTR
![]() Next problem is that all supplied banjos are for M12 banjo bolts, but the OEM water banjo bolts are M14 ![]() Thanks for the info mate, I already sent them an E-mail telling them that I think that they are wrong, will see what they say. Cheers, Leo
#340 (permalink) |
Austrian GTR
Update on the braided line issue! They fit
![]() There are only two things you have to do, first is to turn the hose with the bend for 180°... ...this will work with no problems and Ben from Hel Performance ensured me that this will not influence the sealing in anyway ![]() And the second thing is that you need a M12x1 banjo bolt, which is missing in the kit, so you can attach the hose with the two banjos to the oil connector on the block to the side facing towards cylinder #1... ...just contact Hel Performance and tell them that this banjo bolt is missing and they'll send it to you for free They also sent me the two 14mm banjos that were missing in my kit, so everything's fine now ![]() Will post up some pics once I have them fitted. Already told Ben that it would be good to include this banjo bolt in the kit right from the start as you need it anyway and then it's more obvious where and how the hoses connect ![]() Cheers, Leo
#341 (permalink) |
fourtoes
is milk monitor
Great news Leo, they should include instructions too!
And you my good friend should do a write up or at least post some piccies!!! bob
Blue 30 TWO............................GTR :) To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Like us on Facebook ZEALOU5 turning cars into heroes. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ZEALOU5 Contact: Bobby Proctor Mobile: 07970699470 Website: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#342 (permalink) |
Miguel - Newera
GTR Register Trader
Well done, Leo - glad to hear you found the solution.
You're one step closer to having the Skyline smile back ![]()
#343 (permalink) |
infamous_t
is drunk off pancakes
I've been wanting to do this myself for a while, are you hooking it directly to then bumper feed?
Or dropping the intakes down there? If the former, interested how you end up doing this. Good job so far ![]()
#344 (permalink) | |
Austrian GTR
I'm hooking it directly to the front bumper feed hence I relocated the oil cooler to the driver side ![]() Don't think it will be possible to drop the intakes down there with running twins and reasonable air filters though ![]() But I'm already thinking about making a kind of air box for that area once everything is back in, so the filters are really sperated from the hot air in the engine bay... Cheers, Leo
#345 (permalink) |
jaz
is awesome!
Cars owned: r32gtr
that is exactly what ive been planning for a while now but cant get my head round what i have to do untill the engine is back in and i can trial fit the bumper too
