Under floor heating - GT-R Register - Official Nissan Skyline and GTR Owners Club forum
Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > Non-Skyline/GTR sub forums > Howsie Hosted Rant Forum
Old 3rd March 2010, 10:09 AM   #1 (permalink)
xaero1 is hungry
xaero1's Avatar
Cars owned: 306 Rallye
Under floor heating
Right people, it's been a while since my last proper rant
Under floor heating.
Which absolute inbecile decided this would be a good thing to put throughout my apartment (which I rent) when it was built? Then, which absolute imbecile decided to put underlay and carpets on top of it?
The result is this. Underlay makes it more difficult for heat to rise upwards and into the room. This means my heating elements need to be at the maximum 30 degrees in order for the room temperature to reach about 20.
This means my apartment is using 35 units of electricity per day. According to Southern Electric an average UK household uses 10. Apparently, it would be 3 times cheaper to heat my bedroom using an oil filled radiator than it would to use under floor heating.
I'll repeat that: 3 times cheaper to use an oil filled radiator
That's crazy, absolutely crazy.
I've been really careful with the heating too. Only certain areas have it turned on and even those are on timers. My hot water tank only heats up at night so I get cheaper rates etc.
Let me give you an idea of the difference in bills with heating turned on and heating turned off:
May - August (off) = £89
November - Feb (on - winter) = £401
Ridiculous.
So this is a lesson to all. Anybody that is doing up their house should avoid under floor heating like the plague. You have been warned.
xaero1 is offline   Reply With Quote
Old 3rd March 2010, 01:09 PM   #2 (permalink)
Miguel - Newera is enjoying Fuji.
Miguel - Newera's Avatar
Cars owned: Techno Pro AE86, 280 bhp E30 M3, 500 bhp Knight Sports RX-7, Honda VTR SP2 - Tuned.
We used to have under-floor heating in our old house in Tokyo. Tried it and loved it... nice & toasty floors But were shocked to see it had cost around 600 quid to heat the house for just one month, so we never used it again for 7 years after that. Just used electric oil filled heaters instead which cost a small fraction in comparison.
In Japan mostly fan assisted parafin heaters are used. They're pretty economical, the only pain is filling them up with Parafin from time to time and having to go to the petrol station / home centre to fill 20 litre containers up every couple of weeks. They work well - where we live now can get pretty cold sometimes in the winter... although probably no colder than most of the UK at the same time of the year.
Funny enough most houses (even new ones) don't have central heating in Japan, only air conditioning (Which is a bit useless in the winter)... If we ever get to build our own home around here - I want to make sure we have proper wood burning stove connected to a boiler to heat water in two circuits. One for use, one for heating. Doubt we'd have under floor heating again though!
Miguel - Newera is offline   Reply With Quote
Old 3rd March 2010, 01:16 PM   #3 (permalink)
tonigmr2 is just back from the ring and knackered.
Moderator
tonigmr2's Avatar
Cars owned: MR2 TC Project, R34GTR
Send a message via Yahoo to tonigmr2
That is the way to do it! My parents have underfloor heating which is very toasty (under concrete and tiled floors mind, seems daft to put carpeting on top!!). But they are linked up to a huge wood burning furnace!
UK R34GTR V-Spec :)
You can either have money or stuff. I have stuff.
tonigmr2 is offline   Reply With Quote
Old 3rd March 2010, 01:36 PM   #4 (permalink)
RSVFOUR is looking for a std 32GTR exhaust
RSVFOUR's Avatar
Cars owned: RB26 Stagea , Brabus SLK,1973 Porsche 911 T
Send a message via ICQ to RSVFOUR
Problem is underfloor heating heats the floor not the room .
Unless you have tiles its near as useless
RSV Four FFC
(Flying Fridge Carrier...... now with twin turbos)
Old 3rd March 2010, 06:20 PM   #5 (permalink)
Robbie J is now happy as I've got a new house at last
Moderator
Robbie J's Avatar
Cars owned: GTR R35 and 350z (R33s Gone)
its only worth using if you have that solar or that heat exchanger under the garden....
I'm a Mod, not sure that's a good thing
R35 arrived in June 08
Robbie J is offline   Reply With Quote
Old 4th March 2010, 05:28 PM   #6 (permalink)
craftymonkey has no status.
Cars owned: gtr33
You might find that it has something to do with sound regulations for the apartments.. the flats could have fail the sound checks then they installed underlay and carpets to get it through regs. The electric heating cost is crazy but my friend has just got a £900 gas bill!!!
craftymonkey is offline   Reply With Quote
Old 10th March 2010, 08:19 PM   #7 (permalink)
gavman is out there
gavman's Avatar
Cars owned: OS r32 rally car
rubbish
you just need the correct underlay
gavman is offline   Reply With Quote
Old 10th March 2010, 08:28 PM   #8 (permalink)
gavman is out there
gavman's Avatar
i couldn't disagree more- underfloor heating is the best thing since sliced bread.
however it needs to be combined with a ground source heat pump to be cost effective.
it has cost me just over a grand to heat my house for a year, including hot water, and it's been bare feet and t-shirt right through the winter. there's even an air conditioning unit that takes the heat out of your house in the summer and puts it back in the ground, making your heating run more efficiently
i strongly suspect that your flats have the wrong underlay fitted. any underlay designed to insulate noise will also prevent underfloor heating from working correctly.
also, underfloor heating run from a conventional boiler is very inefficient....
e2a
just checked my leccy bill, £1500 for 18 months including heat and hot water
Old 10th March 2010, 10:24 PM   #9 (permalink)
Zed Ed is sweating on a NIP
GTROC Board Member
Zed Ed's Avatar
Cars owned: R35 GTR
I've got some electric underfloor heating, under tile, and it works well. On all the time, which I think is cheaper than on/off cycles, where the floor loses retained heat.
No experience of it under carpet though.
I'm currently talking with MSV about something tasty for your diaries in November
Thinking Bedford Autodrome, exclusive GTROC track time, drive something from Palmersport too.................................
We're on track for a great 2010 with GTROC events
Zed Ed is offline   Reply With Quote
Old 12th March 2010, 01:51 AM   #10 (permalink)
gavman is out there
gavman's Avatar
mine is under a thick carpet and the proscribed underlay for underfloor heating, and like you say runs 24/7
i have a concrete floor and the combination is still nice and springy/soft to walk on
Old 29th March 2010, 05:18 PM   #11 (permalink)
gtrsmiles has no status.
gtrsmiles's Avatar
Cars owned: r33 gtr v.spec
e2a
Agreed, best way to have under floor heating is with a wet central heating system. Problem with radiators is that they are always next to a wall so a lot of the heat you are paying for is just soaking into the wall, and the rads have to be hot so they are able to emit the heat into the room.
With under floor there’s non of that heat loss, and the water temp can be considerably less and still reach the thermostat temp in the same amount of time as heat is coming from a much larger surface and rising up into the room. Much more cost effective than using conventional radiators. And the posh systems have a digital thermostat timer in each “zone” so you have dining room, lounge, hall and kitchen for example, so you can tune the times and temperatures in the areas on the house to suit your life style (no point heating the kitchen all evening if no one’s going to be in there) making it even more cost effective.
Only thing is its expensive to install so payback period will be very long, but if your having a new central heating system installed its defiantly worth looking into it.
gtrsmiles is offline   Reply With Quote
Old 29th March 2010, 07:55 PM   #12 (permalink)
TAZZMAXX is building robot penguins
TAZZMAXX's Avatar
Cars owned: R35 GTR, Iveco 35C15 truck, white Pug van - Citroen C4 coming soon!
I've never like the idea of underfloor heating as I don't like having warm feet. We do have an open fire in our living room so that's where we spend most of our time. My wife shovels coal on like it's a Pacific loco - sod the carbon footprint! My car drops down to 4 mpg when I really nail it so I'm unlikely to worry about burning fossil fuels.
Old 30th March 2010, 03:05 AM   #13 (permalink)
gtrlux is in red Skyline mode
Registered user
gtrlux's Avatar
Cars owned: Top Secret R32 / R34 sedan
Cool thread,
Had been looking in to this things recently as I am planning for my future house.
Basicly the under floor heating is only eco if you use appropriated boilers, pipes and in best case ground heat or solar energy input.
Here in japan where many old houses have only one floor, they put long flat cussions under the floor (wood or tatami), these cussions get filled with a substance that keeps heat better then water. Throught the middle of the cussion flows your avarge central heater hot water.
So if you want to be eco in a sense of optimal energy usage which equals cheaper heating cost for the household, these are the tree points you have to look at:
1) What floor are you using (stone, laminate, wood ex . . .)??? get appropriated materials for floor heating
2) Choose a new boiler and in best case combine it with solar energy or ground earth heat sources.
3) Don`t go for the cheapest piping/cussion systhem for under the floor, as you need something that spreads heat and is easy to heat up. Then the systhem has to be durable and as many cheap installations loose performace over the years.
gtrlux is offline   Reply With Quote
Old 31st March 2010, 05:27 AM   #14 (permalink)
Turks has no status.
Turks's Avatar
Cars owned: BMW X5 4.8is
Send a message via MSN to Turks
I have just installed this in my house in the bathroom and kitchen, both of which are tiled on a concrete / screed slab. I have used the electric system as this was much easier to install - a wet system would have meant either breaking out the concrete to lay the pipes and re-pour or raise the floor about 100mm to lay the pipes on top of the existing slabs. I know that there are systems that are thinner but resistance wiring was good enough for what I needed.
I have to say that underfloor heating is fantastic, used in the right way it can be very energy efficient. Heat rises so what better way is there to heat a room than evenly distributed heat over the footprint of the room? Wet systems are the most efficient when combined with the correct boiler and heat exchanger - Solar / GSHP / ASHP.
xaero1, as others have said, your underlay is acting as insulation. The heat from the wires isn't conducting through properly and therefore not radiating throgh your carpet as it should. Lots of air pockets for the heat to get through before it reaches the carpet. So, the problem isn't your UF Heating, it is your floor covering... could change the rant to daft Landlords?
Turks.
Turks is offline   Reply With Quote
© 2001-2009 Cem Kocu
