[RB26] dual feed rail + twin bosch 044 setup - GT-R Register - Official Nissan Skyline and GTR Owners Club forum
Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > Nissan Skyline > Tuning: General
Notices
Old 3rd April 2010, 11:28 AM   #1 (permalink)
brtl is unaware they can edit their status
brtl's Avatar
Cars owned: R34 GTR
I'm at the moment building my fuel system,
and a little bit concerned about fuel rail and lines.
avalible parts :
* dual feed fuel rail
* aeromotive FPR
* bosch 044 x2
* fuel filters x2
* cusco 1,2liter swirl pot.
* couple of meters of braided hose 7,5mm
* collection of earls an6 fittings
brtl is offline   Reply With Quote
Old 3rd April 2010, 01:25 PM   #2 (permalink)
R32 Combat is in limbo
Spannering again.
R32 Combat's Avatar
Cars owned: R33 GTR
#2
Be aware that the system tries to return 99% of the pumped fuel when the engine is idleing, so make sure you have a good sized return.
SKYLAB FUSION. The 3rd generation torque split controller for the ultimate driving experience.
This replaces your old G-Sensor for a digital, faster responding, unit along with offering the driver the ability to alter the balance of the cars 4WD power delivery for the optimum balance.
A free fitting service is available at Skylab HQ, which is postcode RG19
Only £229.
plus £10 p&p worldwide tracked postage
Also available in the GTROC online shop
R32 Combat is online now   Reply With Quote
Old 3rd April 2010, 01:35 PM   #3 (permalink)
brtl's Avatar
Cars owned: R34 GTR
thanks for your interest.
thought so too, also wondering if my swirl pot 1.2liters wouldnt be too small for 2x 044 ?
what do u mean by good sized return ?
***934;7,5mm for in/out hoses is good or not ?
cheers !
Old 3rd April 2010, 01:50 PM   #4 (permalink)
Spannering again.
R32 Combat's Avatar
Cars owned: R33 GTR
How many thousand gazillion HP are you running to need 2 pumps?
Only £229.
Old 3rd April 2010, 05:09 PM   #5 (permalink)
brtl's Avatar
Cars owned: R34 GTR
goo question, second pump sounds like an overkilll for me too
my wish is to get some 5** on dyno print
Old 3rd April 2010, 07:21 PM   #6 (permalink)
Spannering again.
R32 Combat's Avatar
Cars owned: R33 GTR
You can see 500 with 1 044 easy.
Only £229.
Old 3rd April 2010, 07:36 PM   #7 (permalink)
brtl's Avatar
Cars owned: R34 GTR
okay even if so is it better to use dual feed entry or is it completely not necessary ?
Old 4th April 2010, 02:15 AM   #8 (permalink)
kismetcapitan's Avatar
Cars owned: BNR32 (RIP), Audi RS6, 2012 BMW S1000RR, 2000 Ducati ST4
#1. I use that setup although my 044s are both in-tank. Same Aeromotive fpr, but one very critical addition. Each end of the fuel rail is fitted with an Aeromotive checkvalve. I run my turbos a bit harder than most, so a single 044 might be at the limit, but two is overkill. That being said, 600bhp cars are right on the fence between single and dual pumps.
But my main purpose for choosing the #1 design is that, with the checkvalves, a fuel pump can fail and although rail pressure will fall by about 0.5 bars, the remaining pump can still support 1.5 bars boost (on my car) and by readjusting the fpr, you could drive around quite normally until you get around to replacing the dead pump.
In single pump systems, a dead pump equals a flatbed. And if it dies when you are hard on boost, you can run lean and melt your pistons. Rare, but it happened to me.
Old 4th April 2010, 01:44 PM   #9 (permalink)
I use a stock rail with -8 fitting one end and a -6 on the other, for the return. Many after market rails actually have a smaller bore than the stock one, the HKS on for example In your third drawing you show the return from the rail going to ther main tank, which is incorrect, it should always go back to the swirl pot.
This is what I made for my car, I may use it with another engine (a 6.3 litre race V6 that drinks fuel, so the very large swirl pot and double 044 pumps were fitted, which is probably overkill for a 500 BHP RB26) :
IrfanView HTML-Thumbnails
Old 4th April 2010, 05:16 PM   #10 (permalink)
RB26 240Z is Nearly Finnished
Cars owned: 1970 Datsun 240z with RB26DETT
I will be running this set up but with the return from the fuel rail going back to the main tank why return hot fuel into the swirl pot ?
RB26 240Z is offline   Reply With Quote
Old 4th April 2010, 05:30 PM   #11 (permalink)
brtl's Avatar
Cars owned: R34 GTR
to keep the swirl tank full.
Old 4th April 2010, 05:33 PM   #12 (permalink)
Spannering again.
R32 Combat's Avatar
Cars owned: R33 GTR
Why bother with any of it? A single pump in the tank is ok.
Only £229.
Old 4th April 2010, 05:46 PM   #13 (permalink)
With hot fuel i am running 2 lifter pumps from the main to keep the tank full.
Old 4th April 2010, 07:21 PM   #14 (permalink)
ru'
ru' is is meh!
ru''s Avatar
Cars owned: M3 'Vert & X90
...This is what I made for my car...IrfanView HTML-Thumbnails
Sorry for the hijack (and the dumb question) - what are the two blue cylinders in between the fuel pumps?
Old 4th April 2010, 07:40 PM   #15 (permalink)
They are fuel filters (cleanable) and there's another one between the in tank lift pump and the swirl pot.
© 2001-2013 Cem Kocu
demoMedia
