| Notices |
LinkBack | Thread Tools | Display Modes |
#216 (permalink) |
Kev@SVM
is @ www.severnvalleymotorsport.co.uk NEWWEB SITE
R35 GT-R Specialists
nice name
kk
Kevan Kemp: SVM - World Record Holder's in 2012 - Tel : +44(0)1952 583 917 - Web: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
#219 (permalink) |
Jm-Imports
is sitting on 1011.4bhp
GTR Register Trader
we are getting there slowly but surely..
new dodson low temp thermo ![]() ![]() front timing chain casing to clean off ![]() setting the camshafts up and timing chain it up (took a little longer than we wanted but had to make sure its spot on) top chains first ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() crank sensors fitted ![]() Timing all done and turned by hand to make sure all ok. So thats Engine built UP and now ready for the AUX and all other bits around the block.. Just need my final delivery for SPE in USA and we are ready to fire it up sometime soon :d ![]() ![]() ![]()
#221 (permalink) |
GTaaaaaarrrrrr!
is very confused by hub dynos
Cars owned: R35 GT-R, E46 M3
Superb Jurgen
Be sure to post some vids of the beast when you crank it up ![]()
Built and maintained by JM-Imports Tuned by Ryan G RIP Tweenierob; the brightest stars burn the fastest |
#222 (permalink) |
Jm-Imports
GTR Register Trader
i had a nice suprise today..
was out collecting few parts etc to be greeted by this box in my office :d GREDDY TD06 SPE HYBRID TURBOS MODIFIED (thanks eugene).. BOOST LOGIC ATI DAMPNER SPE OIL CATCH TANK AND LINES GREDDY HIGH BOOST WASTE GATE SPRINGS. All above supplied by SPE (thanks once again). ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#223 (permalink) |
Jm-Imports
GTR Register Trader
this is the final spec list
JM-IMPORTS 1000BHP JUN-R1 R35 GTR SPEC LIST. ENGINE -JUN 4.0 COMPLETE CUSTOM STROKER ENGINE JUN FORGED AL PISTONS JUN I-BEAM 4.0 RODS DARTON SLEEVES (WET LINERS) JUN BILLET 4.0 CRANKSHAFT JUN BEARINGS BORExSTROKE: 96.0mmx92.0mm,DISPLACEMENT: 3996cc,COMP.RATIO: 8.8 JUN CAMSHAFTS: 264 IN/EX JUN VALVE SPRINGS JUN TITANIUM TYPE 2 VALVE RETAINERS JUN PBB VALVE GUIDES JUN PORTS - INTAKE AND EXHAUST JUN FULLY MACHINED CNC COMBUSTION CHAMBERS JUN GROUND AND RAPPING VALVE SEATS HKS HEADGASKETS HKS EXHAUST MANIFOLD GASKETS ARP L19 HEADBOLTS DODSON LOW TEMP THERMO JUN CUSTOM POLISHED SPACER PLENUM AND MAIN PLENUM BOOST LOGIC ATI DAMPNER SPE CUSTOM CATCH TANK AND LINES SPE MODDED FUEL SET UP AMS ALPHA 1300HP FUEL SYSTEM SPE FPR AND LINES ID2000 INJECTORS GTC 90M TITAN RACE EXHAUST- FULL SYSTEM GREDDY XL TYPE 29 R-SPEC POLISHED INTERCOOLER GREDDY LARGE IC PIPING KIT RADTEC ALUMINIUN RADIATOR BOOST LOGIC OIL COOLER AND LINES SAMCO SILICONE HOSES WATER(BLACK) FORGE HEADER ALUMINIUM TANK FORGE WASHER TANK 5 BAR MAP SENSOR (SPEED DENSITY VIA THISTLE) COBB ECU TURBO SET UP - GREDDY SPE MODDED X2 TD06 20G TURBOS (1100AWHP RATED) GREDDY MANIFOLDS - THERMAL COATED VIA ZIRCOTEC GREDDY DOWNPIPES - THERMAL COATED VIA ZIRCOTEC GREDDY TWIN 40MM TYPE RZ BLOW OFF VALVES GREDDY TYPE RO8 WASTEGATES X2 GREDDY AIR INX FILTERS GREDDY LARGER POLISHED INTAKE PIPES GREDDY TYPE RC WASTE GATE SPRINGS DRIVE TRAIN - DODSON PRO MAX 1000FT/LBS 10 PLATE RACE CLUTCH DODSON BILLET HIGH TENSILE CLUTCH BASKET AND PISTONS DODSON MOTORSPORT/EXEDY FRICTION DISCS DODSON HEAT TREATED STEEL AND SHIMS DODSON NEW SEALS DODSON GTR GR6 H D FWD GEAR LOCK DODSON GTR GR6 MECHANICAL CIRCLIP 1&2 DODSON GTR OIL PUMP UPGRADE DODSON TRANSMISSION FILTER DODSON GTR GEAR SELECTOR PISTON 1&2 SENSOR DODSON GTR GR6 UPRATED O-RING KIT OS GIKEN TCD REAR DIFF PPG 1ST GEAR UPGRADE BILSTEIN SUSPENSION WITH H&R SPRINGS BREMBO 6 POT FRONT BREMBO 4 POT REAR AP J HOOKS GROOVED FRONT DISC OEM DRILLER REAR DISC EBC YELLOW PADS FRONT AND REAR COBB NIS006 UGRADE
| Display Modes | |
