| Notices |
LinkBack | Thread Tools | Display Modes |
#421 (permalink) |
Litchfield
Cars owned: R35 GTR
I took Jurgen's GTR around the block this morning after we have installed the gearbox upgrades including Dodson Promax clutch kit. The car drives like standard with a slightly more positive gear changes
Although I only drove gently up the road and back you can tell the car will be a real animal once setup. The combination of the exhaust and the AMS fuel system rumbling away signal some bad intentions I sure all your hard effort will be worth it Jurgen it was a pleasure to work on a car that this much enthusiasm has gone into ![]() Onto another Nissan GTR race gearbox now ![]()
Litchfield Imports Tel: +44 (0)1684 850999 Fax: +44 (0)1684 850700 Mob: +44 (0)7887 622177 Web: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
#422 (permalink) | |
Kev@SVM
is @ www.severnvalleymotorsport.co.uk NEWWEB SITE
R35 GT-R Specialists
it should be more than 1 week imo, if tuners/trade members can not give their free advice without conflict (you can either take or leave it ) who said any thing about driving around at 70c (we said we start opening a stat@around 70c, fyi the water pumps are fine ! Jurgans car has had the upgrades req,not to run excessive temps rad/stat/ and fan mapping upgrades by gtc unless the whole bumper is changed or redesign eg like the top racing editions every little bit of help with 1000bhp is required I reiterate lower temp stats do work well in this combo...kk
Kevan Kemp: SVM - World Record Holder's in 2012 - Tel : +44(0)1952 583 917 - Web: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
#423 (permalink) | |
johnhanton57
is nervous about what Medusa has become
So not to overload everone with all the detail this is the important part from the science behind engine temps "An engine needs different temperatures. The inlet including the compressor of a turbo and in the inlet trumpets and the inlet valves need to be as cold as possible. A countercurrent heat exchange with forced cooling air does the job. The cylinder-walls should not heat up the air before compression, but also not cool down the gas at the combustion. A compromise is a wall temperature of 90°C. The viscosity of the oil is optimized for just this temperature. Any cooling of the exhaust and the turbine of the turbocharger reduces the amount of power available to the turbine, so the exhaust system is often insulated between engine and turbocharger to keep the exhaust gases as hot as possible." So provided the earlier opening thermostat compensates for the extra heat produced by the extra power and the engine wall temp is 90 deg C then all is good. Therefore it's not the water temp thats the issue its the engine block temp which of course is dictated by heat generated and heat removed so if you are addding more heat due to running more power then you need to keep the water temp lower to take this heat away or circulate it faster. If you are going to run hotter then you need to look at the Engine Oil viscosity to ensure it is correct for the higher temps. As i live in the cold North my preference for engine oil has always been the factory standard and i have not been tempted to go with more viscous oil like others have. If i lived in a warmer climate and had more BHP then this would change
#424 (permalink) |
Adam Kindness
is phu phu phu
on the topic of oils we tend to always run 10w60 in our track cars...
a bit thick for start/stop town driving perhaps but deals with the heat on track. We try to keep oil temps under 100 (thermostatic oil coolers etc). What oil cooler setups are these high power R35's running? PS - John. Do you fancy putting your R35 on the rollers at a RR day in Aberdeen? We have 1 35 coming along already and I'm going to speak to another this afternoon to see if he fancies it.
#425 (permalink) | |
johnhanton57
Hi Adam,
Agee with you completely on the Oil choices and if i ever had the balls to race proper i would probably run with higher viscosity but as i'm a Drag Queen my Engine Oils never get much above 90 deg C. But of course when i do the transplant later this year and am running 850 + BHP then i may have to look again at everyday oils verus when i'm using all the GG's based on what Oil temperatures I see on full Chat and what i see running around town. Would love to do a RR day to check on the Beast as i've not done one for over a year and much has changed since you skelp me at Crail ![]() Quote:
#426 (permalink) |
Adam Kindness
is phu phu phu
I'll be up for a rematch
![]() Were running about 100bhp more now, and a bit less weight ![]() I'll pm regarding the RR day. BACK ON TOPIC for Jurgen. Best of luck at TOTB! Can any of these 35's get round corners as well as they rip up the straights?
#427 (permalink) |
enshiu
is away
Well said administrator
Back to Jurgens topic. Nice car now with the gearbox upgraded. Hopefully you will upgrade the fuel lines too I presume?
Now: R35 GTR JDM - JDM Gen 3.5 Camry - EDM Subaru vivio Past: R33 GTR sgl turbo |
#428 (permalink) | |
BenLinney@GTC
is loving the golden age of the R35
GTR Register Trader
well done good work. bet jurgen will be like a kid at xmas collecting
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. GTC TiTAN * GTC CARBON AERO * GTC COOLING * GTC CLUTCH FRICTION * VR38 HARD PARTS * AccessTUNER PRO RH9 *
#429 (permalink) | |
Jm-Imports
is sitting on 1011.4bhp
GTR Register Trader
this is with uprated OS giken diffs and upgraded gear and clutches... am pleased to say my GTR is the First in the UK with the PROMAX gear and if anybody is considering it (go for it as the characteristics of the car have not changed)..
#431 (permalink) | |
Jm-Imports
GTR Register Trader
will see you next week for the mapping ![]()
#432 (permalink) | |
enshiu
is away
Those are recalled in the US.
#433 (permalink) |
Jm-Imports
GTR Register Trader
after the long trip back having had the Dodson pro max clutches and uprated gear and OSgiken diff fitted - car deservedly got fully washed and polished and we fitted its new Dry Carbon GTC Ltd Edition bonnet.
(i got it customised with white as opposed to all carbon) hope you like it ( its going back to bodyshop for a bit more white and pearl to get colour almost spot on- i wish i was not so fussy at times).. end of next week if time allows we will start mapping. ![]() ![]() ![]() ![]()
#434 (permalink) |
.::TopSky::.
is a Nissan freak.
Cars owned: Skyline R33 GTR (Sparkling Silver) Impreza STi Type RA Vr.5 Supra MKIV Volvo 850R Laser blue
Damn your R35 is a beuty!
Really like the hood!
| Display Modes | |
