MPG - GT-R Register - Nissan Skyline and GTR Owners Club forum
Go Back   GT-R Register - Nissan Skyline and GTR Owners Club forum > General > Off Topic > All things Stagea
Old 22nd May 2010, 06:24 PM   #1 (permalink)
R32 Combat is in limbo
Skyline Section Manager
R32 Combat's Avatar
Cars owned: R33 GTR
MPG
For the record.
I got 570kms out of 58 litres, which is about 27mpg.
This was V-Power fuel.
Thats driving at 80mph with the AC on.
Old 22nd May 2010, 08:09 PM   #2 (permalink)
wagzilla is High maintenance!!!!
wagzilla's Avatar
Cars owned: 1998 stagea 260rs 1957 chevy nomad 200 bmw 528it
you are the man!!!! I never got more then 22 mpg
I'm just lucky to be here?
wagzilla is offline   Reply With Quote
Old 22nd May 2010, 09:54 PM   #3 (permalink)
shh! is unaware they can edit their status
shh!'s Avatar
Cars owned: R32GTR, ,STAGEA 25tRS-V (2WD)
never had better than 17mpg....????
shh! is offline   Reply With Quote
Old 22nd May 2010, 10:40 PM   #4 (permalink)
RSVFOUR's Avatar
Cars owned: RB26 Stagea , Brabus SLK,1973 Porsche 911 T
I should check your O2 sensor I can get that from mine
aka The Grean Machine
My website -
Old 23rd May 2010, 07:39 AM   #5 (permalink)
jimbo54 is unaware they can edit their status
Your lucky l get 12 to 15 mpg but lm fully loaded most of the time.
jimbo54 is offline   Reply With Quote
Old 23rd May 2010, 07:42 AM   #6 (permalink)
shh!'s Avatar
put in new 02 sensor a while back, just the state of tune i think, car was covered in loads of s.w.a.t. stickers when imported, ran a 14.3 at thorny island, thats good for a skyline r33 gts25t, car is defo not stock!!
Old 23rd May 2010, 05:14 PM   #7 (permalink)
wagzilla's Avatar
Then I would say your tune is off...becouse both Brain and mine are not stock...
Old 23rd May 2010, 05:15 PM   #8 (permalink)
wagzilla's Avatar
how much wieght is that...James
Old 23rd May 2010, 05:18 PM   #9 (permalink)
R32 Combat's Avatar
Cars owned: R33 GTR
Where as mine is standard bar air filter.
The higher octane fuel helps too.
I run about ˝ bar vacuum at 80mph, which is nice.
Old 23rd May 2010, 08:01 PM   #10 (permalink)
blitzman is by the sea.
blitzman's Avatar
Cars owned: BMC & Nissan
27mpg at 80mph with the A/C on!!
Tell me what your secret is.
I should be so lucky!
blitzman is offline   Reply With Quote
Old 23rd May 2010, 10:37 PM   #11 (permalink)
RSVFOUR's Avatar
Well r32combat does have a manual series 2 with a neo engine,
Being a manual gearbox helps a lot which is why nearly all series one Stageas seem to drink the petrol
My website -
Old 24th May 2010, 07:15 AM   #12 (permalink)
Not sure on the total weight l carry an electric wheel chair 178LBS two 6ft metal ramps three dogs my partner and on occasions the parrot with cage, so its heavy, perhaps l shouldnt moan about the MPG l get
Old 25th May 2010, 03:37 PM   #13 (permalink)
Rude Dog is mostly relaxing.
Rude Dog's Avatar
Cars owned: 1996 Nissan Stagea RS Four V
Stagea Web Advanced Tune by any chance????
Rude Dog is offline   Reply With Quote
Old 28th May 2010, 09:19 AM   #14 (permalink)
DeanN is unaware they can edit their status
DeanN's Avatar
Cars owned: Masa Stagea S2
Originally Posted by R32 Combat View Post
For the record.
I managed something like 27mpg out of my Series 2 tiptronic when I first picked it up. It was standard tune back then and I was doing 65-70 on the long drive home because I didn't know the car yet.
I recently made an attempt to calculate the mpg from the injector duty cycle and speed. Here are the results.
At 50mph 3.6ms = 5.85% duty cycle
22.23cc/min,133.38cc/min total=8002.8cc/hr
1.76 gallon/hr at 50mph=28.4 mpg
At 30mph 3.3ms = 4.26% duty cycle
16.18 cc/min,97cc/min total=5824.8cc/hr
1.28 gallon/hr at 30mph=23.4 mpg
At 60mph 4.3ms = 7.88% duty cycle
29.94cc/min,179.6cc/min total=10778cc/hr
2.37 gallon/hr at 60mph=25.3mpg
From standing start to 70mph foot down hard 16ms = 85.3 % duty cycle
324cc/min,1944cc/min total=116640cc/hr
25691 gallon/hr at 70mph=0.0027mpg !!!!
These were taken with 2 on board and half a tank of juice on a reasonable day, neither particularly hot nor cold weather. At the time the car was running induction kit, cat back, silenced de-cat and using Tesco 99.
I often use tiptronic mode around town because I think that the auto probably changes up too quickly and hangs onto the higher gears too long. Certainly by using lower gears I see a lower injector duty cycle on my informeter and also on the over-run the fuel is cut down much more in a lower gear than if I let the box decide to keep it in a higher gear.
None of this is by any means proven since I haven't taken guaranteed fuel useage measurements by using the fill up and zero trip meter method. I only made those calculations on a whim after being bored one day.
DeanN is offline   Reply With Quote
Old 28th May 2010, 08:10 PM   #15 (permalink)
R32 Combat's Avatar
Cars owned: R33 GTR
Can you go through your calculations?
Old 28th May 2010, 08:24 PM   #16 (permalink)
DeanN's Avatar
This is what I worked out.
Example. Injector is 380cc/min
So at 9% duty cycle that's 9% of 380 = 34.2 cc/min
Multiply by number of injectors, 6x34.2=205.2cc/min
Multiply by 60 to get hourly consumption 205.2x60=12312cc/hr
Convert to litres ,divide by 1000, 12312/1000=12.312
Convert to gallons, divide by 4.54, 12.312/4.54=2.71 gallons per hour.
Divide 60mph by gallons per hour to obtain mpg. 60/2.71=22.14mpg
If you want a quick way to calculate IDC from IPW at any given RPM, look here Stealth 316 - Injector Duty Cycle Calculation
Alternatively rpm x IPW / 1200 = IDC %
I did post these details on another forum and asked if anyone could confirm the validity of my calculations, but no-one did.
Old 28th May 2010, 08:45 PM   #17 (permalink)
R32 Combat's Avatar
Cars owned: R33 GTR
Looks spot on.
There is a variable, the fuel pressure. It could swing 20psi. Thus varying the fuel volume a 20% or so.
Old 29th May 2010, 10:55 AM   #18 (permalink)
DeanN's Avatar
Looks spot on.
Hmm, yes. I had considered that, but without a fuel pressure reading there's not much I can do about factoring it in.
In an ideal world I would have fuel pressure and fuel flow readings, but this was just something I was thinking about when I was bored one day.
The inspiration for it was from thinking about some of my old cars that had "mpg" displays in them and how they had calculated it. Certainly, it's clear that there are too many variables for a truely accurate calculation. I did even consider going about making a box of tricks to display the values, but that's a little beyond my capabilities and probably taking things too far really.
Thanks for confirming my thoughts though. When you look at the figures, they're not too bad for a big old Datsun estate !
