| Notices |
| View Poll Results: Which spark plugs should I get for my R33 GTR? | |||
| BKR7EIX |
22 | 66.67% |
| BCPR6EIX-11 |
3 | 9.09% |
| PFR6A-11 |
8 | 24.24% |
| Voters: 33. You may not vote on this poll | |||
SeR GTR
Actually non of the above, for my GTR I chose the NGK Iri-Top 8. It's a cold iridium NGK cold plug w/ heat range of 8. And has the GT-R plug JIS spec.
SeR GTR
Don't use BKR starting NGK plugs because those are ISO spec, not JIS for the GTRs. The code for IRI-Top 8 is BCPR8EIX. Their heat ranges are from 7-9. So if it's 9 you want then the part num. is BCPR9EIX... I chose 8.
96gtrvspec
First let's address the IRI (WAY)(TOP)(MAC) series. These plugs have a 0.6mm Iridium center electrode with a tapered cut ground and are sold under the name Iriway, Iritop and Irimac throughout Japan and other select countries. In the USA and Europe these same plugs have been released under the IX iridium series and can be identified by there alphanumeric part #’s. The list below shows appropriate interchanges. Both the IRI series and the IX series are produced in the same NGK factories in Japan. They are identical in construction; the only difference is packaging and marketing.
IRI series Alphanumeric part number IRIMAC8 DCPR8EIX IRIMAC9 DCPR9EIX IRITOP7 BCPR7EIX IRITOP8 BCPR8EIX IRITOP9 BCPR9EIX IRIWAY7 BKR7EIX IRIWAY8 BKR8EIX IRIWAY9 BKR9EIX
frostmotorsport
is working for a living... how boring!
Cars owned: '97 R33 GT-R, Evo 1 RS rally car, 3 Mk. II Escorts and many more!
personally, I'd stay away from Iridiums. They caused me nothing but mis-fires on my GTR. I now run NGK PFR7A-11 gapped to 0.7 as recommended by my tuner.
AlexH
is running out of cash
Cars owned: R33GTR
i just use whatever MGT racing fit for me...............
it's due another service soon and i want some more boost and garth will do some more mapping. im just not stoping till mark says enough is enough, were no where near that point yet so im sure ill get through some more sparkplugs before were done. makes it much easyer when someone else does them for you
#10 (permalink) | |
tyndago
is 2009gtr.com
Always had good luck with iridums on GT-Rs over about 5 years. RB26DETT , RB26 Spark Plugs
#12 (permalink) | |
tyndago
is 2009gtr.com
How much power? When was the last time the coil harness was replaced? When was the last time the coils were replaced? What is the condition of the spark plug boots?
#14 (permalink) |
frostmotorsport
not sure if being serious or sarcastic...
#15 (permalink) | |
GT-R Glenn
is aware Veilsides street R32 gtr ran 8.612 @ 172.5
MPH (Radials)
I get confused, great minds think alike , however, fools seldomly differ ... Not sure which is most appropriate...
