Removing / Cleaning GTR Exhaust tips / outlets - Page 2 - GT-R Register - Nissan Skyline and GTR Owners Club forum
Go Back   GT-R Register - Nissan Skyline and GTR Owners Club forum > General > Nissan GT-R > Nissan GT-R Maintenance
Old 11th October 2010, 08:35 PM   #21 (permalink)
misters3 is loving the torque in the E70!
Cars owned: BMW 335D, R35
Originally Posted by charles charlie View Post
Outstanding Chris.
Great pics and explanation.
This place needs more doers!
I would if i could without breaking my car
But post#17 should be made a separate thread and sticky ---mods???
Actually so should your rear camera thread for Non-Nav Cars? I had to post that link to someone today! Took me a wee while to find it!
misters3 is offline   Reply With Quote
Old 11th October 2010, 10:24 PM   #22 (permalink)
Chris956 is 420bhp RWD is interesting in the rain :-0
Chris956's Avatar
Cars owned: From GTR To GT3 & Cayman R
Outstanding Chris.
Chris956 is offline   Reply With Quote
Old 12th October 2010, 08:44 AM   #23 (permalink)
hambroski is map switching!
hambroski's Avatar
Chris - Thank you so much. Now I just need to find some ramps and I can get to work!
hambroski is offline   Reply With Quote
Old 12th October 2010, 08:53 AM   #24 (permalink)
ANDY400R is looking at GTRs again
ANDY400R's Avatar
Cars owned: Storm white R35
When I replaced my tips for some titanium ones I found that when I reversed the clip so that the bolt was on the other side I could then actually get a socket on it by going thru the gap between the two tips and therefore not needing to touch the undertray at all. Just makes it that much easier to remove for cleaning takes about 2 minutes only.
ANDY400R is offline   Reply With Quote
Old 12th October 2010, 09:12 AM   #25 (permalink)
Chris956's Avatar
Hambroski - just reverse it up onto the kerb or a couple of bricks. You don't need that much room under it.
Andy400r - I thought about that but decided not to because I will not be taking them off again as cleaning them now is a doddle in situ.
Old 12th October 2010, 11:26 AM   #26 (permalink)
countvonc is wanting a GT1 car as a track toy
countvonc's Avatar
Cars owned: R35, Navara, Classic Scooby & Turboed MX-5, X1/9(!), now sold..Evo X (382/400)
You dont need to. I did it on the ground without removing the tray.
Regards - CvC
Y pipe & 90mm Titan
NIS006 Custom Cobb
Interior carbon
Tints & stuff
White bumpers that match the metal bits.
countvonc is offline   Reply With Quote
Old 12th October 2010, 11:36 AM   #27 (permalink)
matthill83 is unaware they can edit their status
matthill83's Avatar
Originally Posted by WingedBeast1968 View Post
Autosol and paper towels. Probably get finger cancer at some point.
I vouch for autosol polish, it also brought the shine back to my alloys after the winter road salt corroded the plished rim. Great stuff, been around for ages
matthill83 is offline   Reply With Quote
Old 14th October 2010, 11:32 AM   #28 (permalink)
R1Mark is Now running 400mm Alcons
R1Mark's Avatar
Cars owned: Cosworth, Monaro VXR SC, R35 GT-R
Originally Posted by Chris956 View Post
Then off with the under tray which was easy to do with the collection of 12mm and 10mm bolts and 4 plastic clips.
Do the plastic clips just lever off with a wide tipped/bladed screw driver?
"Shoot your engine from your hip"
R1Mark is offline   Reply With Quote
Old 14th October 2010, 03:18 PM   #29 (permalink)
Chris956's Avatar
Yes they do . Put a flat end screwdriver on them and wiggle the central piece up. Once a tiny bit proud you can grab it with your fingers and continue the wiggle till it pops out.
Old 17th October 2010, 08:41 PM   #30 (permalink)
BrianGraham is unaware they can edit their status
Thumbs up GT-R exhaust
Solution : I squirt ' Muck-off ' on the end of the pipe and then go for a coffee.
When I get back it just washes off with a hosepipe.
If its really bad - use a brush as well
BrianGraham is offline   Reply With Quote
Old 18th October 2010, 11:04 AM   #31 (permalink)
Chris956's Avatar
But that doesnt solve the issue of the inner pipe sticking out through the tailpiece IMO looking a bit cack. Moving the tailpieces out just a small amount gives it a more finished look.
Old 10th November 2010, 09:08 PM   #32 (permalink)
enshiu is away
enshiu's Avatar
used the high pressure water gun did help some but not like this !!!!!
Old 14th February 2011, 02:21 PM   #33 (permalink)
damien7579 is unaware they can edit their status
Cars owned: R35 of delight and Lexus RX400h
how long does it take others for their clean exhaust tips to go black? for me it's one 10 min drive and bright shiny polished tips are completely black inside cleaning them is pointless. I thought AP would reduce this somewhat but seems not to.
damien7579 is offline   Reply With Quote
Old 21st February 2011, 03:10 PM   #34 (permalink)
Graham@York is a !! MAD GIT !!
Graham@York's Avatar
Just removed my tips without removing any panels or jacking the car up,
Remove the inners first put a jack under the outer tip and lift it about 25mm, this makes it easy to get a socket in, once the inners are removed the outers are fully accesible
Graham@York is offline   Reply With Quote
Old 21st February 2011, 11:38 PM   #35 (permalink)
roketman is owner
roketman's Avatar
The best product I have found to keep them clean as well as for ease of cleaning is a product called REJEX.The y use it on planes so they can just rinse off bugs and grime.It also works superb on rims.
roketman is offline   Reply With Quote
Old 24th February 2011, 07:42 PM   #36 (permalink)
bobel is testing the limits of adhesion
bobel's Avatar
Cars owned: R35, X5
Autosol does the biz for me, but haven't removed them yet for a proper clean, may give this idea a go though, is there enough room to get some penetrating fluid onto the nuts, don't think mine were removed before and don't want to ring them.
bobel is offline   Reply With Quote
Old 24th February 2011, 09:03 PM   #37 (permalink)
Its a bit awkward seeing if the wd 40 has covered the clamp bolts, i snapped 1 bolt but i got it out and replaced it with another one, the bolts have about 25mm sticking through the nut so you can put it in a vice to get the snapped stud out.
Old 24th February 2011, 09:08 PM   #38 (permalink)
Chris956's Avatar
A WD40 can with a straw will reach no probs. A healthy squirt left for 24 hours to penetrate will avoid snapped studs..........hopefully !
Old 24th February 2011, 09:19 PM   #39 (permalink)
I'm much to impatient to wait 24 hrs
Old 10th March 2012, 09:15 PM   #40 (permalink)
peterwbaker is unaware they can edit their status
Hey, super useful information here - thanks for giving me a short cut to "research" :-) Peter
peterwbaker is offline   Reply With Quote
Tags
clean, exhaust
