kannibal
is far away
Stud broken
hello, i got one stud hot side broken,
any advice or a safe way to remove it? Where can i buy new stud? ps: pictures in next post as i must have 15 post to link pictures ![]()
Darbo
Cars owned: R32 GTR's/wrx-sti-ra rallycar currently building a group 4 mk1 escort 2.3 duratec powered
these work ok but you need to be carefull to drill dead centre
Broken Stud Sheared bolt Extractor Set on eBay (end time 08-Dec-10 19:29:42 GMT)
SmigzyGTR
is eating Lambo's in his 588bhp/ton Honda :)
HardcoRe GTROC Member
Cars owned: R33 GTR, 500hp K20 EG6 Turbo
Once its drilled you should (hopefully) be able to remove the rest of the stud. Then just use a fresh one, if not, you'll have to re tap it. Not too difficult though.
drewzer
is going RB30 soon!
snap on easy out and 1/8 drill bit.
Drill all the way through snapped stud, hammer easy out in. Place turbo in the vice and as you are putting load on the spanner to undo the stud, tap the back of the easy out with a hammer to try and break the torque. Works every time (the snap-on easy outs in particular are very good from my experience)! Drew
kannibal
is far away
make a mark with a hammer and a peak object on the center
drill for the biggest extractor i can introduce inside insert the extractor heat a little bit and the stud comes, not easily, but surely ![]()
Chris Wilson
Torx bits make good stud extractors in an emergency. Sometimes it's safer to drill out completely and Helicoil back to stock thread size. A broken stud extractor is usually pot hard and a total nightmare to get out.
kannibal
is far away
I had already the case, with a smaller extractor, that the extractor break itself at the same level than the screw itself.
I had to drill the extractor itself .that was a nightmare as the extractor itself is very hard.
#13 (permalink) | |
kannibal
is far away
![]() i get a lot of difficulties to find stock part (air box, exhaust suspension,...) for the homologation here. I wait for my 50 post to make a post in wanted section ![]()
