#16 (permalink) | |
steven2mum
is cycling round the ring in September
Cars owned: BMW M5 E60 / Impreza RB320
Sorry, but I am also confused, I don't understand the reference to the diff cooler in the context to the transmission oil cooler.
cheers Quote:
#17 (permalink) |
Kev@SVM
is @ www.severnvalleymotorsport.co.uk NEWWEB SITE
R35 GT-R Specialists
sorry the word difference not dif should have been used
Kevan Kemp: SVM - World Record Holder's in 2012 - Tel : +44(0)1952 583 917 - Web: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
#19 (permalink) | |
Kev@SVM
SVM/GTC GEARBOX OIL COOLER & SUMP KIT
This is a kit with we have developed and tested in conjunction with GTC : ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#20 (permalink) |
Chubby
is no longer content with 700bhp and is now going for
850 bhp... but now has 900bhp... Yipee
Cars owned: At present I have GT-R R35, Range Rover Sport, Mini Cooper S (turbo), Abarth 500, Boxster S & 911 GT3 gen 2.
I'd recormend the Forge system - I think it fits and looks better - I have had one on my car and it does the job, is very quite in operation and even when the going gets tough (if you know what i mean) keep the temps all under control.
R.
#22 (permalink) |
Chubby
I have only been on track 3 times, once at Silverstone GP (Trax), the Ring (when you were there) and a very wet Spa.
The temps are much lower when the system operates, which is approx 95 deg before the pump cuts in - the temps not only stay low, but on a cool down lap usually return to below 95 deg before the lap is over. I have seen 124 and 126 deg before fitting - I think the highest I have seen is around the 110 deg mark with the kit. I have also had a slight upgrade on the cooler / washer bottle which should help as well for this year. R.
#23 (permalink) |
R1Mark
is Now running 400mm Alcons
Cars owned: Cosworth, Monaro VXR SC, R35 GT-R
Out of interest, what is the ideal temperature for efficient safe operation of the transmission?
www.aberdeenbikers.co.uk |
#24 (permalink) | |
Chubby
I have been told that the transmission oil does not go off until at least 140 deg, but then the HPC's have said 110 deg which was then raised and rasied again so I think now they say 125 deg... Also I have found that the temps are different if I use the trans in manual or auto... But I'm sure there is someone who will be able to give you the correct answer. I also change the oil on a regular basis - I have doen 15k miles and have had 4 engine oil changes and 3 trans - just to keep me happy - 18k the diffs will be next - and I don't feel that i abuse the car too much... ![]()
#25 (permalink) | |
Arcam
is back from the Ring
GTROC Board member
Cars owned: Many & Various
Having said that with the Willall TML I ran to 129 degrees with no problems, you must also bear in mind that even if you cool the transmission the diffs still get too hot and need the oil replacing on a regular basis, I swap the 2 diffs out after a max of 2 track days.
#26 (permalink) | |
David.Yu
is loving Stealth Zilla with over 700hp!
Cars owned: R35 GT-R, Volvo XC90 4.4 V8, 190hp Abarth 500 (wife's)
What is the washer bottle situation with the Forge kit? Does it need to be removed/replaced with a smaller one? Do they supply a smaller one if needed? Can't imagine driving a road car without a washer bottle!
#27 (permalink) |
Chubby
I have had the FMIC from forge which has the washer bottle fitted - I believe the washer bottle is now slightly smaller and a different shape to allow better flow of air over the Trans intercooler.
#28 (permalink) | |
Arcam
GTROC Board member
#29 (permalink) |
paparazzi
is now at 624awhp/608ft lb thanks to Spec V turbos
and GTC's custom Etune
I currently have the HKS Kansai cooler which is relatively inexpensive and cools the coolant before it goes to the tranny heatexchanger thereby allowing it to absorb more heat. It works well for me as locally we have no race track and the best I do is spiritied street driving.
If you're tracking the car I would recommend either the HKS or the Greddy as neither of them require external pumps and the installation is alot cleaner. The biggest advantage IMHO of those 2 over the pump based coolers is there is one less electrical item to fail.
#30 (permalink) | |
David.Yu
Oh and they happen to cost MORE than the Forge or SVM options!
