SVM "The Hulk" - 218.1mph World Record Holding R35 GTR - GT-R Register - Official Nissan Skyline and GTR Owners Club forum
Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > Nissan GT-R > R35 GT-R Projects
Notices
LinkBack Thread Tools Display Modes
Old 7th February 2011, 09:36 PM   #1 (permalink)
Kev@SVM is @ www.severnvalleymotorsport.co.uk NEWWEB SITE
R35 GT-R Specialists
Kev@SVM's Avatar
Due to the Demand for this thread to begin, we are posting it with the car not quite complete but it will still give you an idea of what has been created by Severn Valley Motorsport. We apologise for the delay but as with any project of this magnitude these things take time,
The Beast is not yet in it's full glory so you may find certain entities changing during the course of time. Also the car will have it's full photo shoot complete once all the final stages go together so please don't worry about some pictures not giving you the finished result. This is work in progress, many thanks once again for all your support, from people on the Forum to Suppliers and not to mention All the crew at SVM, family and friends. Regards & Big love from KK
"THE HULK"
and the transformation begins.............................
KK09GTR was and we repeat was a great acheivment for Severn Valley Motorsport a car that changed the way we thought and the boundaries that we were at.
But then one night when the glow of the light started to flicker From the infamous RED L.E.D Badge it started to take control, only this transformation was headed in one direction only !!!!!! The rage from within had begun.
Like a virus it spread quickly until all it's path would be consumed........
They say that a picture tells a thousand words, well low and behold ladies and Gentleman the "Hulk" Lives !!!!!!!!!!!!!!!!!!!!!............................. ................
Specification Build (Current to date)
Engine
SVM HULK Spec Forged Blueprinted Unit 4.2L
92.4 Billet Greddy Crankshaft assembly & boost logic Crank damper/ rotating mass dynamically balanced
98mm Darton modular Integrated deck system (wet liners)
SVM specification longer Carrillo connecting rods
SVM Custom CP Comp Pistons & Higher Quality wrist pins & ARP bolts
ARP L19 Head Extra high Strength Bolts
Ferrera Valve Package with larger inlet and exhaust valves and titanium retainers
Tomie 280 Profile cams with 11.3 lift
CNC 5 angled valve pockets and CNC Balanced Porting
Ported and Matched Inlet Manifolds
GTC Billet winged engine sump
HKS 45ml colder spark plugs
Okada plasma Direct coil packs
Induction
Large Greddy Throttle housings (awaiting first delivery from Greddy)
Greddy modified steel manifolds/modified with v bands couplings & SVM support system
GTX GT35 Garrett Turbo Chargers with ball bearing core assemblies & V Band Fitment
Tial 44mm external waste gates V Band Fitment
Custom 80mm down pipes Zercoated
80mm hard pipe kit with SVM Green pipe couplers and murray hose clamps
80mm MAF pies with HPX MAF sensors
HKS Blow off Valves
GTC 102mm Titanium Exhaust system with 102mm GTC Y pipe fully resonated
KN High flow air filter system with ram pipes & 90mm intakes
Cooling
Martons lightweight Aerospace bar and plate intercooler (only one of two ever made for an R35 GTR)
Radtec high capacity engine and gearbox radiators housed into bumper
Radtec alloy power steering reservoir
Radtec water high pressure header tank and combi cam breathers with braided lines
Radtec Race Spec radiator
Radtec central block breather catch tank
GTC water hoses and ECU Rad program
65 deg thermostat and housing
Fueling
1600 ID Injectors High flow injectors
Billet 12mm fuel rails with twin Dash 8 fuel lines
Triple 1200bhp SVM Designed fuel pump system with swirl pot
Fuel lab fuel regulator with braided lines
Engine Detailing
Mines carbon engine cover
Carbon battery and brake servo cover
Titek carbon cooling panel
Hulk imperial pearlescent colour coded 1200bhp engine with specialist detailing
Colour Coding of various parts
Transmission
Albins 1st to 6th Gear set kit Uprated & High Strength
GTC 14 plate clutch system
Upgraded 4wd Gearlock system
Uprated Diff’s
SVM gearbox cooler kit with additional fan and thermal control/motul pump and braided lines
GTC Billet gearbox high capacity oil pan
SVM synthetic 13lts duel clutch oil
Shell helix racing oils
Chassis
KW coil overs Variant 3
KW club sport suspension with alloy top mountings
Eibach billet spacer pack with titanium wheel nuts
Eibach front and rear "hollow" light weight anti roll bars
GTC rose jointed top arms
400mm Top Secret Big Brake conversion front and rear (This is only used for Road and track use not Drag)
Electronics
45psi digital boost gauge
HKS AFR and knock meters with twin additional oxygen sensors
COBB ap with
GTC steering wheel maps race and road fuels
COBB ap nis 06 upgrade with launch control
Willhall Racing shift light
All mapping by Ben linnley GTC (2 fuel maps: Road 99 ron Race fuel 120 ron)
Exterior
Complete inside out re-spray in metallic imperial green pearlescent, eleven coat system & sponsors decals
Top racing carbon racing front bumper (part painted)
GTC Carbon bonnet (part painted) gold heat protection
Top Secret carbon gas bonnet lifts
Top Secret Front Towing eye for Track use.
Aeromotion’s S2 Active split wing
WALD Rear carbon diffusers
WALD side skirts (painted black and green))
WALD rear arch extensions (painted black)
GTC carbon boot lid
GTC Carbon Race mirrors mounted on pillars
Carbon exhaust surrounds
Carbon/Black wrapped roof
MCR front and rear side markers
L.E.D front and rear GTR badges
L.E.D angle eye day light running lights
LSD doors
Privacy Glass
Wheels & Tyres
3 sets of wheels and tyres - show/road/track
Show
22" i forged carbon coated show wheels/ green pin stripe / bar code graphics
22" Pirelli Tyre package. R 295/25/22 F 265/30/22
Road/Track
20" Volks Racing light weight wheels Toyo R888 315/30/20 tyres
Track
18" Rota drag wheels with hossier non expanding drag tyres
Interior
Cobra front carbon ultra light race seats / technology foam /alcantara fabrics & Custom Logo’s
6 point Roll Cage Custom built to SVM Spec with removable bars
TAKATA 4 point race harnesses
Full carbon interior package ( 12 piece kit) inc Carbon rear speaker shelf
Result & More Snap Shot's of the Beast itself !!!!!!!!
Estimated power 1200bhp
Estimated performance 1/4mile Sub 9 seconds
Designed, Engineered and built by Severn Valley Motorsport UK /Euro record holders 2010
Kevan Kemp: SVM - World Record Holder's in 2012 - Tel : +44(0)1952 583 917 - Web:
  • R35 Servicing & Repairs
  • Consult 3, Cobb & Syvecs
  • Conv - From 570R to 1800R
  • UK & Euro Record Holders 2010,2011 & 2012
  • 8.93 @ 168.56mph @ Santa Pod - Oct 2012
  • World's Fastest R35 GT-R @ 218mph - March 2012
  • World's Fastest standing 1KM 208.2mph - July 2012
Kev@SVM is offline   Reply With Quote
Old 7th February 2011, 09:50 PM   #2 (permalink)
GTRSTAR is talking To Kev @ SVM Because He Can Turn A Two Ton Turd in to Shit Off A Shovel!
GTRSTAR's Avatar
Thumbs up We're Not Worthy!
AMAZING!
Theres something about British flamboyance that neither the Yanks or the Japs can match
Nice work Kev, congratulations for pushing the boundries, this ones going down in the history books
GTRSTAR is offline   Reply With Quote
Old 7th February 2011, 09:57 PM   #3 (permalink)
Bajie is as Bajie does ...
Bajie's Avatar
Cars owned: 2.2TDCi ST
Send a message via MSN to Bajie
Thats a bloody good demo car.
I like it and hate it.
Good advertising.
If the milk turns out to be sour, I aint the kind of pussy to drink it!
WAR : If I invade Kentucky Fried Chicken, wings will be free in my house!
Mondeo TDCi ST
Bajie is offline   Reply With Quote
Old 7th February 2011, 09:59 PM   #4 (permalink)
erikv is no power
Loving the wing m8!!!
erikv is offline   Reply With Quote
Old 7th February 2011, 10:32 PM   #5 (permalink)
BenLinney@GTC is loving the golden age of the R35
GTR Register Trader
BenLinney@GTC's Avatar
Thumbs up
mega build KK's the man
Bring on TOTB & Santa Pod
GTC TiTAN * GTC CARBON AERO * GTC COOLING * GTC CLUTCH FRICTION * VR38 HARD PARTS * AccessTUNER PRO RH9 *
Old 7th February 2011, 10:38 PM   #6 (permalink)
Ludders is Jap Drag Series Champion
GTROC Drag Coordinator
Ludders's Avatar
Cars owned: R.I.P.S Drag-R + The Sherbet Lemon + R34 Nur Spec R1 + R35 GTR 650R
Well done KK.
Will this car be at Santa Pod on the 6th March??
Support the GTROC in their quest to win Ten of the Best this year. Make a weekend of it or at least come along to the main day on the Sunday.
VP Race Fuel and Tyres at great prices for the GTROC - Mickey Thompson - Hoosier - M&H - TOYO.
Owner of the worlds quickest Street R34GTR built by R.I.P.S Racing and the worlds quickest Street R33GTR built by Abbey Motorsport.
Ludders is offline   Reply With Quote
Old 7th February 2011, 10:45 PM   #7 (permalink)
Kev@SVM's Avatar
Originally Posted by Ludders View Post
Well done KK.
bit tight that one....never say never kk
Old 7th February 2011, 10:49 PM   #8 (permalink)
Nigel-Power is playing a Game
Nigel-Power's Avatar
Cars owned: a wheelbarrow
Awesome and a half ! welldone SVM
Nigel-Power is offline   Reply With Quote
Old 7th February 2011, 11:36 PM   #9 (permalink)
Ludders's Avatar
Can I put it down for the July TOTB Team?? And your car of course??
http://www.gtr.co.uk/forum/147390-ten-best-2011-a.html
Old 8th February 2011, 03:10 AM   #10 (permalink)
T80 GTR is unaware they can edit their status
T80 GTR's Avatar
Cars owned: R35 GTR, R34 GTS, BMW 325 Cab, Audi S5, Audi S3, Audi A3 Cab, Audi A4, Evo X
Beast
First thing that pops to mind...... beauty and the beast in one
You can tell Great imagination and passion went into this build.
Great work KK 10/10 from me. this history in the making.
P.s great write up reminds me of a comic
T80 GTR is offline   Reply With Quote
Old 8th February 2011, 05:21 AM   #11 (permalink)
Jakester is unaware they can edit their status
Jakester's Avatar
Cars owned: 3.0L Supercharged Maxima
Amazing, looks like a real beast, congrats!
As for flamboyance, seriously, have you seen the Hennessy Venom GT , he (John Hennessy), is crazier than SVM!!!
Jakester is offline   Reply With Quote
Old 8th February 2011, 06:54 AM   #12 (permalink)
MrGT is think I might want a r32 gtr
MrGT's Avatar
Cars owned: series 2 R33 GTR (cold climate spec)
excellent write up, awesome spec and looking car, very intrested to see dyno plot and 1/4 mile slips.
TIB
GTROC Area Rep-North West
Behold a white GTR, and the man who sat in it was Death and hell followed with him.
upcoming Northwest events.
Northwest mini meet and photoshoot, (date yet to be comfirmed)
MrGT is offline   Reply With Quote
Old 8th February 2011, 06:55 AM   #13 (permalink)
EvolutionVI is testing new Whiteline parts
HKS GT800 abuser
EvolutionVI's Avatar
Cars owned: 600+PS Evo 6 TME + Evo 9 Wagon + Evo X & GTR soon
Enough pictures...put it on a racetrack(not the 400meter ones) and show that it will survive more then a day full throttle action without problems....if so,it should be called monster and a good democar
As written above,its a love and hate thing,i pretty much love it for the way it looks,aggressive and mean,on the other side i think it looks like a drawing from a comic and i would never go anywhere in it as everyone would point the finger on it and would think the owner is 19y,has a small dick and a looks like this:
Love or hate....i like and hate it...
800 horses are better then 600 horses....
Old 8th February 2011, 07:14 AM   #14 (permalink)
Too many people nowadays seem to pretend they are somehow "classier" by choosing subtle colors. However, I personaly think that a supercar of this calibre with such attention to detail to boast about should also have a flamboyant paint job, which in this case it does ! and I think its a brave move by SVM and I also like the fact that SVM has persisted to do what they like to do and prove others wrong in a sense that this GTR seems to be making its way as being one of the best looking GTR's built, and shall make a statement it definitely makes me feel like a 10 year old looking at it
I say Brilliant Job Love it mate !
Old 8th February 2011, 08:32 AM   #15 (permalink)
alloy is awesome
alloy's Avatar
There are things i love and things i hate, but you have to applaud the work you have clearly put into it!
Can't wait to see what it can do on track!
alloy is offline   Reply With Quote
Display Modes
© 2001-2013 Cem Kocu
demoMedia
