Which bearings to use ? - GT-R Register - Nissan Skyline and GTR Owners Club forum
Go Back   GT-R Register - Nissan Skyline and GTR Owners Club forum > General > Nissan Skyline > Engine Mods
Old 13th March 2011, 11:20 PM   #1 (permalink)
SupraT71 is unaware they can edit their status
SupraT71's Avatar
Cars owned: 1994 R32 GTR
Im building my engine and ordered a bunch of stuff from the states. But there seems to be some trouble getting ACL bearings so i have the choice to go with
Power Enterprises, Nismo or Clevite instead or keep waiting for ACL bearings which are taking forever.
Power Enterprises have these options but i have no experience with them
Ranking: Thickness
0/Pink: 1.5 (-0.015/-0.011)
1/Purple: 1.5 (-0.011/-0.007)
2/Brown: 1.5 (-0.007/-0.003)
3/Green: 1.5 (-0.003/+0.001)
4/Yellow: 1.5 (+0.001/+0.005)
5/Blue: 1.5 (+0.005/+0.009)
Nismo / i have no idea about they are not even on their site but he offered me them
Clevite have been often used in Supras and are offered
Standard and .25 over
This is all that i ordered btw
CP Piston Set with Rings // 86.5mm(0.02")
Eagle H-Beam Connecting
Nissan N1 Oil Pump
Tomei Combination Kit (1.2mm Thick, 87mm Bore) for RB26DETT
*Metal Head gasket
*Metal ThrottleGasket
*Metal Intake Manifold Gasket
*Metal exhaust Manifold Gasket
*Oil gallery orifice
ARP Head Stud Kit
ACL Race Series Con Rod Bearings
ACL Race Series Main Bearings //Standard Oil clearence
2x - ACL Race Series Camshaft/Thrust Bearings & Small End Bushes
Nitto Oil Pump collar
SupraT71 is offline   Reply With Quote
Old 14th March 2011, 12:19 AM   #2 (permalink)
R.I.P.S NZ is down to 7.28 @ 197mph worlds quickest skyline GTR
R.I.P.S NZ's Avatar
Cars owned: R32 GTS4
I can help with the acl race bearings if you like, e-mail me.
RIPS is NZDRA Champion 2010/2011/2012, IHRA Champion 2011/2012
Worlds quickest and fastest RB30 6.99 and 192.7mph on the 1/4
CC/D, DD/D and EE/D NZ record holders and multiple track record holders with a street based RB30
Mild to wild RB30s, 7,8,9,10 sec street/drag cars built to order, custom fabrication, worldwide shipping
e-mail
Old 15th March 2011, 12:53 AM   #3 (permalink)
Hja-Ozz is a Wangan addict
Hja-Ozz's Avatar
Cars owned: Jun Super Lemon RII
I would hold out for the ACL's ... never had any issues with them
Hja-Ozz is offline   Reply With Quote
Old 15th March 2011, 05:38 AM   #4 (permalink)
SupraT71's Avatar
Thanks, ill send you an email if dont go with the nismo bearings
yeah thinking about doing that, just dont know how long it will take and i would like to start putting the motor together and get it ready as soon as possible
Old 15th March 2011, 11:12 PM   #5 (permalink)
SupraT71's Avatar
but has anybody used the Nismo ones, saw them here
Nismo - Engine Parts - RB26DETT - Nengun Performance
Nismo introduces the High performance Conrod Bearing set. These same bearings were used in the Le Mans 24 hour race and compared to stock beaings they have 20% more load compacity and according to Nismo they also can withstand 60% more heat and give twice as much more protection than standard bearings.
1 X Conrod Metal set = 2 Halves. 6 or 12 Halves are needed for a complete set.
1 X Main Bearing Inner Set = 2 Halves
1 X Main Bearing Center set = 2 Halves
Old 16th March 2011, 05:44 PM   #6 (permalink)
.::TopSky::. is a Nissan freak.
.::TopSky::.'s Avatar
Cars owned: Skyline R33 GTR (Sparkling Silver) Impreza STi Type RA Vr.5 Supra MKIV Volvo 850R Laser blue
Some guy in Sweden used Nismo bearings i think, he runs a T88-38GK and around 1000hp
.::TopSky::. is offline   Reply With Quote
Old 17th March 2011, 11:28 AM   #7 (permalink)
markdett is unaware they can edit their status
markdett's Avatar
Im putting nismo's in mine cost me about 300AUD for the lot. My tunner recommend only using them, and he has built some of the quickest rb26's in perth.
markdett is offline   Reply With Quote
Old 24th March 2011, 10:50 AM   #8 (permalink)
Nismo bearings are used in Nismos race cars so they are pretty good
Old 31st March 2011, 10:08 PM   #9 (permalink)
adamsaiyad is running the beast :)
Banned
As far as i remember the nismo bearings i heard of started to flake or peel off not on one car but a few a tuner in south africa used them he commented saying the multiple layers of the bearing formation werent very good so they used to peel off the top soft white metal bearing surface.
Advantages to nismo bearings is that they are like nissan bearings and power enterprise you can build with some really good clearances across the board and in effect blue print your bottom end to some what of a degree.
Personally a good bearing should cater for all kinds of crank shaft journal sizes like Power enterprise or Nissan or Nismo, as far as i know tomei bearings are the same but are actually acl.
adamsaiyad is offline   Reply With Quote
Old 29th July 2011, 01:17 AM   #10 (permalink)
GTS4-R is living that R35 life
i used undersized acl race bearings and had my crank cut (.025 under) within 1000 miles it spun a bearing.... dunno yet if it was a poor machining job that my builder didnt double check the clearances or perhaps the crank got too much heat when welding on the jun collar..... but after this experience im turned off from ACL..... I wanna know more about nismo bearings (like who makes them for nismo)..... if they dont quite do it for me than OEM nissan it is
GTS4-R is offline   Reply With Quote
Old 29th July 2011, 02:05 AM   #11 (permalink)
R.I.P.S NZ's Avatar
How can you say that when you don't even know what caused the problem?
I'd put money on it NOT being an issue with the ACL bearings.
e-mail
Old 29th July 2011, 04:12 AM   #12 (permalink)
i never blamed the ACL's but like i said it turned me off from them. I really prefer graded bearings to "standard" Nissan probably spent millions R&D'ing that very thing.....
honestly seeing you in here praising acl had me step back a second. i mean your reputation precedes you.
my motor is coming back out this week so hopefully i get a good idea of what really happened..... its just a shitty situation.... ive got so much money itno my car now and ive barely driven it in 2 years. This was a refreshly rebuilt engine (je 87mm, eagles, n1 pump etc, ground crank acl race undersize etc) and within 1000 miles this happens (it got built the first time due to a spun oem bearing from det on a shitty jdm tuned ecu) this time we barely got done seating the rings and were just starting to tune it (power fc).... werent even into the area of 4psi with "det-cans" hooked up.... NO knock events whatsoever and bam.... she starts knocking again..... i dont know whats to blame, yes. but now i very weary of many things (i was always skeptical of welding the collar on) for all i know the regrind messed up the radius fillet and it caught a bearing... who knows. but anyways im getting back into it now with a brand new r34 crank and tomei oil pump this time..... if you have some guidance feel free.... im always open to info
Old 29th July 2011, 04:22 AM   #13 (permalink)
xxfr is hibernating
Errr, start with a good engine builder first. The rest will work out.
xxfr is offline   Reply With Quote
Old 29th July 2011, 04:25 AM   #14 (permalink)
Sub Boy is a nana driver
Sub Boy's Avatar
I have been told by a few places that ACL Race bearings are softer than Standard, This protects to crank, but may not last as long?
Old 29th July 2011, 04:29 AM   #15 (permalink)
GT-R Glenn's Avatar
Its not that easy to measure the difference in grades anyway ....
Measure the crank and if its within std spec, order standard bearings....
Old 29th July 2011, 04:32 AM   #16 (permalink)
lol..... im doing it with a very knowledgeable friend this time.... we've already nerded out on every other aspect of this thing. we bounce alot of ideas off each other and it works out..... two heads are better than one.
Old 29th July 2011, 04:42 AM   #17 (permalink)
R.I.P.S NZ's Avatar
If the clearances were correct it will alomst certainly be an oil supply issue.
Welded on the oil pump drive......WTF?
e-mail
Old 29th July 2011, 05:13 AM   #18 (permalink)
hytech is 2009 Night Speed Drag Wars Champion
hytech's Avatar
Cars owned: 2 x R32 GTRs & 1 x R33 GTR V-Spec, 1 x Evo Drag Car
x2.
GTR the badge all V8 boys fear!!!
Hytech Engines Street R32 GTR - 10.86 @ 130mph (209kph)
hytech is offline   Reply With Quote
Old 29th July 2011, 05:58 AM   #19 (permalink)
it gets even worse..... the idiots at the machine shop cut off the collar round part (that rides and seals the front main) so once the crank was put in the guy is like WTF?! thats gonna leak out! than they took back the crank and built up a ton of weld and than machined it down to the correct size to fit in the seal again.... i was like WHAT?!?!? he assured me it would be fine, and they had "special machines" to do that..... all i could think is BENT CRANK! i voiced my concerns over and over again.... once i started the motor and did a few miles i figured i was good..... wrong i was.....
i dunno if they checked or balabced the crank after doing that. that could be the prob, or it might not be.... it was a dumb situation. the machine shop had a very good rep (surprisingly) and i foolishly listened.
she'll be coming back with a vengence soon enough......
Old 29th July 2011, 11:15 PM   #20 (permalink)
GT-R Glenn's Avatar
You CAN without a doubt , weld a crank.
Its not uncommon to weld them up on the journals to offset grind them to stoke the crank etc:
But, its not a matter of getting the mig out and letting rip willy nilly , its quite a tricky process, theres no reason why you couldnt weld that part, but it would be totally unecessary if the engine builder guy had a brain ....
