Help stagea 1996 25x Speedo - GT-R Register - Official Nissan Skyline and GTR Owners Club forum
Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > Off Topic > All things Stagea
Notices
Old 18th March 2011, 09:20 AM   #1 (permalink)
rbwot is unaware they can edit their status
Hi there i have a 996 stagea and the speedo is busted i think the odometer reads 9999999 the fuel reads top the temp reads top .. rev works but not properly and the speedo doesnt rise past 0 any ideads on how to fix or would i need a new dash cluster ... cheers guys simon from new zealand
rbwot is offline   Reply With Quote
Old 19th March 2011, 10:47 AM   #2 (permalink)
LozGT is ...
LozGT's Avatar
Cars owned: R33 GTSt, R33 GTR, Avensis Tourer, Stagea RSfourS
Hi There
The first things I'd check would be continuity - check connections at the speedo and also at the ECU. I can't find anything that refers to this sort of fault specifically so I'd be looking for loose connections, short circuits and other potential sources of electrical problems. Are there any signs of modification/intervention/bodges/tinkering with the instrument binnacle?
LozGT is offline   Reply With Quote
Old 19th March 2011, 11:04 AM   #3 (permalink)
Chairman Stagea Owners Cl
RSVFOUR's Avatar
Cars owned: RB26 Stagea , Brabus SLK,1973 Porsche 911 T
Send a message via ICQ to RSVFOUR
sounds like its been taken apart. a new cluster may be the only way to sort things out.
The cluster is easy to take apart - the plastic front just unclips so you are unlikely to be able to tell if its been played with.
Hardly matters though if its US at the moment
Might be worth checking the earth is ok to the loom . There are a few screw on eye connectors bolted to the printed circuit. Black is earth (usually) so it might be worth making a new earth just to make sure.
You cant get the connectors round the wrong way - they are all completely different sizes .The speedo sensor wire is the black/white one 3rd or forth on the single row connector . ( top right thin connector looking at the back of the cluster I think)
Thats about all you can check.........but it does sound like its been messed with . These clusters are very easy to take aprt and notoriously difficult to put back right.
© 2001-2013 Cem Kocu
demoMedia
