markdett
markdett's R32 gtr restoration/build thread
Hello there people. So i thought it was about time to get a build thread started to show the progression of my R32 GTR, From "rotting on the front lawn" to a fully built/restored R32 GTR.
Ok so heres my story..... Bought the car when i was still a first year apprentice. Was actually looking for an r32 gtst, when this came up for a fairly cheap price. The reason for it being cheap the body work wasn't all to shabby. The roof's clear was starting to go dull, and it had a bit of rust around the rear window near the drivers side 1/4 glass. So i wieghed my options, cause the thing was pretty damn cheap and decided to buy it and get all the body work soughted out later down the line (little did i know about how hard it was saving with a loan and still stuck on apprentice wages). The car was driven most weekends for a few years (as i still hadnt got my liscence). When it wasn't being driven it use to sit on my front lawn, soaking up some of australia's finest rays. The paint of course got worse. The dull patches started to lift and spread from the roof, to the bonnet, to the boot and down the 1/4 panels. All the clear coat was now flaking off. To top things off i was driving it one day and the thing started to missfire, did a compression test, and hey presto number 2 cylinder had about 26 psi in it. This happened when i was about a 3rd year apprentice. There was no way in the world I would have been able to save for a paint job, and an engine rebuild on the wages i was on, especially having my loan repayments coming out every month. So the poor thing sat on my lawn and rotted even further ![]() So now i have fully payed the car of, and am also a fully qualified nissan technician, So i thought it was about time to get the ball rolling. I pulled the engine out myself last year around november/december. Was a pretty easy task considering some of patrol mine sight vehicles we have to pull engines out of). Fully stripped the motor down and found that number 2 piston had cracked a ringland (pretty much melted). So there was the cause of my engine failure. Did alot of research about engine modifactions and decided to go with this parts list... TOMEI OIL PUMP TOMEI BLOCK RESTRICTOR TOMEI SUMP BAFFLE TOMEI CONRODS TOMEI PISTONS 86.5mm NISMO BEARINGS TOMEI VAVLE GUIDES TOMEI TYPE A VALVE SPRINGS TOMEI TYPE B PONCAMS HKS CAM GEARS HKS TIMING BELT N1 WATER PUMP APEXI POWER FC D-JETRO TOMEI EXPREME MANIFOLDS GARRETT GT2860 -5''S TOMEI DUMP PIPES NISMO PLENUM HKS FUEL RAIL HKS 700CC INJECTORS TOMEI INTANK FUEL PUMP GENUINE HEATER/COOLANT HOSES ARP HEAD STUDS ARP MAIN STUDS ATI 1000HP CRANK DAMPNER HEAD PORT AND POLISH (attempting myself) TORQUE PLATE BORED/HONED FULLY BALANCED AND BLUEPRINTED CRANK GRUB SCREWED AND POLISHED (long snout crank) Now i know theres probably alot of stuff ive missed out, but ill post as i go on. The engine is also currently at the machinsts, and is then going to be assembled by yoda himself, Anthony Scali at Xspeed perth (bottom end only) As for the exterior of the car, FULL RESPRAY AND RUST CUT OUT (think i might go black with the new PPG BMW/Lamborghini approved satin clear). WORK XD9 18X10 +18 GENUINE NISMO FRONT BAR CARBON FIBRE INTERCOOLER DUCTS JUN CARBON FIBRE FRONT LIP TRUST REAR PODS CARBON N1 BOOT AND BONNET LIPS SIDE SKIRTS N1, REAR SPATS CARBON FIBRE BRAND NEW OEM FRONT AND REAR WINDSCREEN MOULDINGS/SEALS BRAND NEW DOOR AND WINDOW SEALS CARBON FIBRE WIND DEFLECTORS KEEP THE OEM REAR WING So for now thats my basic list of things i will be doing to the car. All engine work (apart from the machine/assembly of the bottom end) will be done myself). Here are some photos to keep you entertained too.. ![]() HKS cam gears and cambelt with greddy clear cover ![]() HKS timing belt ![]() N1 water pump ![]() N1 water pump ![]() TOMEI block restrictor ![]() TOMEI conrods ![]() TOMEI pistons ![]() TOMEI pistons ![]() longnosed crank shaft ![]() WORK XD9 18X10+18 ![]() AGAIN ![]() AND AGAIN ![]() CARBON N1 REAR SPATS ![]() AND AGAIN
markdett
Have also started the head port whilst the engine is away. Purchased a delux head porting kit off ebay, with a cheap $30 long nosed die grinder.
INLET: Knife edge the splitter Remove all casting marks Clean up bowl areas 80 grit and manifold match EXHAUST: Removed bump Mirror polished COMBUSTION CHAMBER: Keeping the quench pads Mirror polish combustion chambers Here are some photos INLETS ![]() COMBUSTION CHAMBERS MIRROR POLISHED ![]() AND AGAIN (LOOK AT THOSE DET MARKS) ![]() EXAHAUST PORTS, BUMPS REMOVED AND MIRROR POLISHED ![]() EXHAUST PORTS ![]() INLET PORTS (with balancer tube attached) ![]() ![]() ![]()
fourtoes
is milk monitor
Awesome
![]() Subscribed!!! ![]() bob
Blue 30 TWO............................GTR :) To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Like us on Facebook ZEALOU5 turning cars into heroes. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ZEALOU5 Contact: Bobby Proctor Mobile: 07970699470 Website: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#6 (permalink) | |
fourtoes
is milk monitor
![]() Bob
fourtoes
is milk monitor
Have you got any pics of the car to share with us
buddy to get an idea of how it looks now? Before all of the hard work begins that is? ![]() Bob
turbob12
is nursing 9 points
Cars owned: R34 GTT
Good thread mate but it looks like you've had a bit of an accident in your swimming shorts and they've sneaked into your second last picture. It's not always a good thing to share that kind of thing.
R32 GTR R32 GTR
is the owner of the Best R32 in 2011 :)
Cars owned: R32 GTR, BMW E36 Turbo, Toyota GT86
subscribed
![]() Where did you get the Carbon N1 Rear Spats from?
#15 (permalink) |
markdett
UPDATE:
So more pictures for your viewing pleasures ![]() one of my storage rooms haha ![]() billet radiator support brackets from power house racing ![]() was quite shocked to find this joined on the back of the crankshaft as the clutch felt like an OEM one. Its on OS GIKEN twin plate ![]() damaged number 2 pistons with melted ringlands ![]() and again ![]() head porting kit ![]() red VHT wrinkle paint anyone ![]() brand new genuine N1 front bar ![]() tomei sump baffle ![]() sump oil return holes enlarged ![]() tomei metal gaskets for inlet side ![]() then engine bay ![]() purchased an engine bay dress up kit with stainless allen key bolts and purple dome washers ![]() the interior ![]()
