KevrevsGTR
is catch me if u can!
Cars owned: R33 GTR
splutter when warm
Hi have r33 gtr when ran from cold to norm temp no probs but then restart when hot idle rises to 1800 then apply throttle car runs rich and splutters. idle when cold 1050 idle when warm 1250. had dignostics and coolant temp sensor fault. also just changed inlet gasket as leaking but problem still the same. has anyone else had same problem? ive ordered new sensor to try. thanks
#2 (permalink) | |
KevrevsGTR
Cars owned: R33 GTR
high idle
KevrevsGTR
Cars owned: R33 GTR
idle problems
after sensor change and reset ecu car settles around 1350 hot but about the same intial startup but then whilst warming up drops to 1050 then eventually back up to 1350? If i unplug air temp sensor on plenum hot / cold makes no difference? If i unplug idle valve when cold idle speed drops but makes no difference when hot? any suggestions cheers
