Fitting R33 GTSt front calipers to Series 2 RSFourS - GT-R Register - Official Nissan Skyline and GTR Owners Club forum
Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > Off Topic > All things Stagea
Notices
Old 16th May 2011, 07:54 AM   #1 (permalink)
LozGT is ...
LozGT's Avatar
Cars owned: R33 GTSt, R33 GTR, Avensis Tourer, Stagea RSfourS
I was hoping that somebody had some experience of fitting R33 GTSt front calipers to a Series 2 RSFourS. Do I need to change much? I think they pretty much bolt straight on but are the brake line connectors the same?
I would really appreciate any advice or hints and tips on this subject.
LozGT is offline   Reply With Quote
Old 16th May 2011, 07:10 PM   #2 (permalink)
R32 Combat is in limbo
Spannering again.
R32 Combat's Avatar
Cars owned: R33 GTR
Also, if anyone has any info about the pipes required to fit the rears, that would also be cool.
SKYLAB FUSION. The 3rd generation torque split controller for the ultimate driving experience.
This replaces your old G-Sensor for a digital, faster responding, unit along with offering the driver the ability to alter the balance of the cars 4WD power delivery for the optimum balance.
A free fitting service is available at Skylab HQ, which is postcode RG19
Only £229.
plus £10 p&p worldwide tracked postage
Also available in the GTROC online shop
Old 16th May 2011, 07:24 PM   #3 (permalink)
Andy_P is 516atf...MENTAL!!
Andy_P's Avatar
Cars owned: R33 gtst
You'll need some inserts to go into the mounting holes....bolts are different sizes.
Otherwise pretty straight forward.
The lines are slightly different arrangement but I'd definately suggest adding some braided lines.....help a lot!
Andy_P is offline   Reply With Quote
Old 16th May 2011, 09:54 PM   #4 (permalink)
Chairman Stagea Owners Cl
RSVFOUR's Avatar
Cars owned: RB26 Stagea , Brabus SLK,1973 Porsche 911 T
Send a message via ICQ to RSVFOUR
As you both have the Rs four s I would expect things to bolt on ok - the stock s brakes are different to a seroes 1
even on the series 1 cars any skyline brakes seem to fit (obviously discs have to be the right size for the caliper)
Re caliper bolts - They are a few different sizes bolts and threads Eaiest way is to get the calipers complete with bolts
Ive fitted 33 34 and APs to Stageas . Braided hoses are always a good idea If you are uprating the brakes. Not always needed but a good idea
Old 16th May 2011, 09:56 PM   #5 (permalink)
LozGT is ...
LozGT's Avatar
Thank you Mr P. Are you saying that the bolts on the standard Stagea front calipers are smaller than the mounting bolts holes on the GTSt calipers - so I will need some inserts to make up the difference? That shouldn't be a problem. Where do you recommend to purchase braided lines?
It's always tricky this sort of thing - well the information gathering anyway. I was talking to someone else this morning who said that everything just bolted on. I guess I will know for sure when I come to do it. Mr P - did you perform this conversion yourself recently?
Thank you Brian - I was typing when you posted your information - I will see what's what when I come to do it. The only reason I want to up-rate the brakes is so that I know I have more capability. I drive in a more family style these days and will probably never need better brakes...
Old 16th May 2011, 10:14 PM   #6 (permalink)
stag-boy is unaware they can edit their status
stag-boy's Avatar
im finding that under heavy braking i get a not too heavy but noticable shaking, is this because it has small discs? (compared to the cars size)
and would uprating the discs and pads make a marked difference or a transfer/uprating would be better? as you are discussing?
or just live with it?
forgive me for sounding ignorant but i'm a bit of a novice still.
stag-boy is offline   Reply With Quote
Old 17th May 2011, 11:48 AM   #7 (permalink)
LozGT is ...
LozGT's Avatar
The shaking you describe sounds like something out of round/warped to me. This is more likely to be warped discs - this can happen with age and is not necessarily indicative of a fault. Replacing/up-rating them would sort this out. Although once upon a time I remember buying some front discs for my GTSt and they were warped to start with - they were a budget disc but I didn't expect them to be warped.
Just out of interest - is it 'disc' or 'disk'?
Old 17th May 2011, 12:17 PM   #8 (permalink)
Spannering again.
R32 Combat's Avatar
Cars owned: R33 GTR
It's disc as opposed to disk'ette'
Only £229.
Old 17th May 2011, 04:32 PM   #9 (permalink)
LozGT is ...
LozGT's Avatar
You're right - a disk or diskette is a magnetic storage medium....
A disc is a disc....
Old 17th May 2011, 07:21 PM   #10 (permalink)
stag-boy's Avatar
okay thats not the end of the world.
id better add decent pads and discs to the list
Old 27th May 2011, 05:54 PM   #11 (permalink)
Spannering again.
R32 Combat's Avatar
Cars owned: R33 GTR
I'm using R33 GTSt pipes to accompany the R33 GTSt rear calipers.
Simpling reallyfold over the heindslab doorstarting.
Only £229.
Old 27th May 2011, 09:53 PM   #12 (permalink)
LozGT is ...
LozGT's Avatar
It's very inconvenient having to use different brake pipes... I may go for braided lines. Can anyone recommend a good place to get some?
Old 28th May 2011, 06:22 AM   #13 (permalink)
Spannering again.
R32 Combat's Avatar
Cars owned: R33 GTR
Personally, I'd use standard pipes because that have the correct pipe clamps for security, or get nismo pipes because that are perfect.
Only £229.
Old 28th May 2011, 08:06 AM   #14 (permalink)
LozGT is ...
LozGT's Avatar
Maybe I will stick with those pipes for peace.....of mind
Now to find some front pipes. I don't want to change the rears yet....
Old 28th May 2011, 05:01 PM   #15 (permalink)
RSVFOUR's Avatar
Ive got nismo braided hoses on mine front and rear - fitted perfectly
© 2001-2013 Cem Kocu
demoMedia
