GT-R Register - Official Nissan Skyline and GTR Owners Club forum - View Single Post - anyone have to hone rod small end?
Old 25th September 2011, 07:25 PM   #4 (permalink)
R.I.P.S NZ
R.I.P.S NZ is planning MGAWOT III, are 7s imminent? lol
R.I.P.S NZ's Avatar
Cars owned: R32 GTS4
Chinese rods quite often need so much work done to them you end up spending more than you would have to buy decent ones.
You don't hone the big end tunnel to get the correct bearing to crank clearance.
You need to get the tunnel within spec you so have the correct crush on the bearings.
You then select the correct grade of bearings to suit your journal or grind the journal to suit the clearance you want to use.
Rob
