#18 (permalink) |
wardiz
is looking for rear suspension bar from v-spec
I did changed my timing belt with a friend (actually my friend did most of the job) and this how to was very usefull. I will post some pictures of the job.
One thing I would add : put the car in 5th or 6th gear is definitely not recommanded according to my friend. Better to block the flywheel this way : on the gear box remove the rubber cap (passenger side) to get access to the fly wheel. This is a small access but large enough to insert a screwdriver. Then ask your friend to turn the pulley while you're watching the fly wheel for a hole. Insert a strong screwdriver in the hole to block the fly wheel. Then you can undo the crank pulley bolt.
#19 (permalink) |
GTR PERFORMANCE
is LOVING THE R33 GTR
Yep mate a very important point there when we do the timing belts on the gtrs thats exactly what i do, just simply lock the flywheel so crank is then fixed
#20 (permalink) |
Marky_GTSt
is a Fire Engine
Cars owned: Skyline GTSt
Good writeup, I would like to add something though.
After putting the new belt on and turning the crank, I like to line up the marks and recheck the tension as you can sometimes find the belt is more slack than intended once its been round. Might be worth adding in the torque wrench settings too, if the bottom pulley or belt tensioner come loose it can be quite bad. I was just looking at the figures but I think I have bad data as the difference between the RB25 and RB26 crank bolts is wildly different. P.S. The Skyline is one of the easier timing belts to do, I can think of a lot of cars that are far worse but not many that are easier. ![]()
I am Jacks complete lack of surprise. Last edited by Marky_GTSt; 11th June 2012 at 05:38 PM.. |
#21 (permalink) |
geoffree
Yes ring gear stopper for an Rb26, balancer bolt torque is 330 to 340ft lbs.
You could get away with direct gear+handbrake in a GTSt, balancer bolt torque is only 105 to 115ft lbs. I use 3/4" gear not 1/2" drive stuff for a 26, too much flex. Tensioning a Nissan belt is by-the book. If you go Gates I suggest a bit looser or you'll be doing the job again. Great photos, another suggestion is to rag up those intercooler pipes, you need to be positive nothing has accidentally dropped in.
#22 (permalink) | |
Marky_GTSt
is a Fire Engine
I am Jacks complete lack of surprise. |
#27 (permalink) | |
SeR GTR
I might want a BNR34 lower cover if that's the case.And some quick Qs. - Is it required to have loctite on putting in new tensioner studs? - Do you really need to put oil on the crank pulley bolt when tightening it back? - And is it safe to say that on 33 and 32 GT-R, 5th gear can be used also when loosening the crank bolt? Because I know many also use 5th instead.
