RB26 240Z
is Nearly Finnished
Cars owned: 1970 Datsun 240z with RB26DETT
Oil Drain Return Question
Have bought some new GT2860-5 turbos and have modded my original metal oil drain pipes to fit (enlarged the holes) my question is i have 2 metal pipes one has a 90 return one has a bend in it which one does on the rear turbo ?
Any Pictures ?
Austrian GTR
is finally enjoying his GTR again
Cars owned: Golf IV TDi-PD, R32 GTR
90° return on the rear...
![]() ...for the front bend one you may need a spacer fabricated ![]() ![]() ![]() HTH Leo
RB26 240Z
is Nearly Finnished
OK have the front turbo in front of me i can see what you mean about it hitting the casing and fitting a spacer for clearance, what about cutting off the pipe at the base moving it around so it clears and re-weld it back on ?
RB26 240Z
is Nearly Finnished
Yep as long as i can fit some thick alloy to make it.
And some more gaskets.
Austrian GTR
Get yourself a 15mm thick spacer made and everything is fine
![]() And you need one more gasket, and that won't be that expensive ![]() You can also cut and reweld it, but the more decent way is a spacer as you don't need to mess around. Cheers, Leo
GTS4-R
90 on the rear but honestly i life to toss that and use 2 45's and custom it up.... that 90 really becomes a traffic jam for oil exiting the turbo
RB26 240Z
is Nearly Finnished
Thanks for all the replys have found out that Garrett do a oil return pipe kit for the GT2860 turbos for the Skyline GTR and are around £12.00 each so i have ordered 2 new ones that are going to fit first time.
