Sniper1st
Supertech valvetrain package ??
Hey, I'm building my RB26 and looking at Supertech products
saw this package which is really a good deal: http://ipg-supertech.com/cart.php?ta...category_id=68 Valve Spring and Titanium Retainer Package ------- SPRK-ts1015/rb26 Supertech Complete Valve set 1.00mm oversize ----NIVN-1032, NEVI-1032 Supertech Bronze Valve Guides --------------------GDE-NSR7-ET Tomei cams 272 lift 10.25 will be revving 8800 rpms 800+whp do you recommend using this set up, any bad experience, anybody running them ?? are above parts enough? what do I need more does it worth going 1mm oversize valves??
#2 (permalink) | |
Red R Racing
is building tough RB engines
#4 (permalink) | ||
Sniper1st
I've BW 91-79 turbo rated 830whp I'm going to max out this turbo ![]() any more input
TurboSE
is working on getting this motor back together for
summer.
wow...good find, thank you.
This package, B Poncams...6-700 street whp...any suggestions? Was running a T78 before the rebuild...
RBJETT
Cars owned: BCNR33, C34 RSV
Exhuast gases are less dense than inlet mixtures thus take up more space, to keep good flow exhuast valves need to be bigger
TurboSE
summer.
I understand the +1 on the exhaust side as I'm sure the OP does, the puzzling part is that Supertech seems to offer this package as +1 on both In and Ex...I emailed them to check.
andy@amt
The trouble with the gtr head is the exhaust ratio is way down on the inlet for a turbo cylinder head this is why I said put bigger exhaust valves in, you can put oversize inlets in but unless you mod the port right it won't make much improvement for the cost of doing it.
Sniper1st
so what you mean is putting 1mm oversize on the exhaust side only, will be more gain than getting 1mm oversize for both sides
so intake side will remain stock, stock guides, or have to change thank you
#12 (permalink) | |
black bnr32
is it recommended to remove the intake squish pad if going +1mm on both sides?
#13 (permalink) |
andy@amt
What Iam saying is unless you mod the inlet port enough putting 1mm bigger valves in will not see a big increase for the money it costs, don't leave the standard guides in fit the supertech ones.
#15 (permalink) |
TurboSE
summer.
So, before i order (sorry for beating a dead horse), I'm just getting the exhaust valves from Supertech, and sticking with stock intake valves.
Should I get in. and ex. valve guides and seals from them (they'll work on the stock in. valves correct)? I'm also unsure about springs. I can't find specs on Poncams (B) to help me decide. I've heard of wear issues with duals, but I don't know that it'll be an issue with the small amount of street use the car will get. Spring specs from Supertechs site
