Originally Posted by fourtoes
Hey Leo, yeah the torque setting on the larger bolts i basically adjusted my toque wrench until it would undo the bolts without clicking, once it didnt click i knew that was how tight they were, if that makes sense?.
Can't remember where i got the 'O' rings from but i know i found some good ones which were particularly good resistance for brake fluid. I'll try and find out what i used for you buddy.
hth
bob
Thanks buddy, would be great if you can find something from the O-ring
Also thought about contacting Brembo, but I doubt they'll answer
Regarding the tourque, mine are already disassembled...
...should have thought about that earlier
@Mikey
You get all the rebuild stuff here:
Zeckhausen Racing
Just measure your pistons and order the correspondent seal kit
Cheers,
Leo
