| Notices |
Satansbodyguard
is .......
Cars owned: R32GTR
Running R32GTR Bigger/Uprated Brakes With No ABS Your Opinions Please
i'm just looking for your opinions on Running without ABS on a big brake set up on an R32GTR
is the pedal feel better ? are they more or less likely to lock up ? as R32GTR's are early in the development of ABS does this make it any less valuable ? ETC..... thanks Nigel
fourtoes
is milk monitor
Nige I've driven mine now without abs, 6 pot front 4 pot rears. And I persinally can't feel anyy loss of benefits to be honest. I did lock my brakes before when I had abs so not too sure how well it was working anyways?
Difficult to make a comparison on how it feels pedal wise as since removing the abs I fitted new calipers to the old setup all round. I'm delighted with how mine feel is all I can say buddy. ![]() Bob
Blue 30 TWO............................GTR :) To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Like us on Facebook ZEALOU5 turning cars into heroes. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ZEALOU5 Contact: Bobby Proctor Mobile: 07970699470 Website: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Sub Boy
is a nana driver
I still have the ABS on mine, the good thing about the old ABS is You would really have to be leaning on it to activate it....it's pretty slow, but I've found it handy at the second corner at my local track (first big braking point from about 160kph)
Try it with the big brakes first, you may find you don't need to remove it, I just changed the Master Cylinder to a R33 GT-R one, and the pedal is perfect.
SPEED MERCHANT
is at GTROC.ORG !!!
GTROC Board Member
Cars owned: ARKHAM
Removed my ABS unit back in March of this year and despite not tracking it this year I've felt no difference so far ... free'd some engine bay space too!
GTROC BOARD MEMBER GTROC FACEBOOK EDITOR GTROC NATIONAL EVENTS MANAGER To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - Sponsored by I.A MOTORSPORT / MEISTER R / SERIOUS PERFORMANCE / ECLIPSE CAR AUDIO / SHARP SIGNS |
gavman
is out there
Cars owned: OS r32 rally car
got big brakes and i removed the abs a couple of years ago
it was triggering too early on some bumpy downhill stretches, especially into tight bends. so we pulled it and i got an immediate improvement. so recommended for competent drivers plus you get a weight saving
Satansbodyguard
is .......
Cars owned: R32GTR
hi
i'm putting my check list together and time is running out on the decision about the whole brake set up i still can't decide one way or the other ![]() a wise man once said "its your decision if someone else advises you and you stack your car that wouldn't be good ! " very true !!! so its been a few months on from when i started this thread has anyones opinion changed or does anyone else have an opinion i'm slightly leaning towards no ABS but........ Nigel
Asim R32GTR
is Looking for a hakosuka GT / GTX
Cars owned: R32GTR LHD
I removed ABS on my car also, made no difference to the pedal feel.
What made HUGE difference was going from BM50 to BM57 brake master cylinder from a R33GTR. I tried everything, bigbrake kit, braded lines, adjusting the pedal free travel. So, if you have a BM44 or BM50 brake master, change it out to a BM57 BM44 23.8mm BM50 25.4mm BM57 26.9mm
#9 (permalink) | |
Satansbodyguard
is .......
Cars owned: R32GTR
List..... 1. brake stopper 2. R33GTR Brake master cylinder unit 3. braided hoses 4. bias valve/adjuster ?? 5. bigger callipers poss ...X308 Brembo (front), lotus 4 pot (rears) 6. bigger discs 7. ABS ???? Nigel
#10 (permalink) | |
cox
is waiting to drive his godzilla
Cars owned: Honda Nsx, GTR 32, Bmw 320d Msport
i already have the other parts ready to fit....
fourtoes
is milk monitor
The standard BMC's have front/rear bias adjustment built in Nigel, so its not advised to add an aftermarket bias adjuster. Al and I were wondering what the large screw on the oem bmc does and if it actually adjusts the bias? anyone know if this is possible? tried it?
cheers ![]() bob
#12 (permalink) | |
Satansbodyguard
is .......
Cars owned: R32GTR
Nigel
#13 (permalink) |
balashark
is looking forward to that rb roar again
can you get an r33 gtr with no abs? i am thinking of removing the abs from my 200sx i have an r33 gtst with no abs, but wouldnt mind a bigger bmc from a gtr but it needs the 3 outputs
#14 (permalink) |
Fil
is Pleased to have the RB25 running and my car back
on the road!!
Cars owned: RB25 powered Sil80
I've got a Z32 BMC on my S13, which was always one of the tried and tested S-Body upgrades.
I don't think you need a three outlet BMC to get rid of the ABS. Pretty sure you can use a 'T' off the front outlet to go to the front brakes. You can buy ABS removal kits for S-Bodies that give you all the bits you need. Edit - I think the Z32 BMC is a BM57
#15 (permalink) |
Fil
on the road!!
Where's the screw Bob? Are you sure it's not a plug that holds the proportioning valve guts in?
