timmd10
Cars owned: skyline r33 gtr
HELP PLEASE
right here we go,
havent driven my car much this year its a 1995 r33 gtr vspec stage 1 tuned, did a oil, oil filter, plug change in march drove it a few times since then but then not for a month or two and got it out the other day let it warm up and took it out as soon as i put my foot down it was running rough, when i put it under load its spluttery it still pulls but something isnt right. its sounds like a scooby. when in netural and i rev it it revs fine like nothing is wrong. i could smell oil when i stopped is it running rich?? just trying to get a idea incase there is something i can do before i take it to the garage. im going to get a new coil pack but surely if it was that it wouldnt rev fine when in netural. help please thanks in advance
Nocturnal
GTR Register Trader
Cars owned: Widebody BNR32
Take your spark plug out and check the plug?
Could be foul plug. Check your CAS also, sometime they come loose and will do things like that.
User Name Changed to MeisterR
GTROC Offer To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
signalr32
Um... did you check the coil packs.. sometimes you dont clip them back in all the way and that can cause it.. Also check the iginition chip thing near the back of the head..
You could just have a bad coil pack or a bad plug.. Also what did you gap the plugs too?
RBJETT
Cars owned: BCNR33, C34 RSV
Check the plugs are gapped to 0.8mm as this helps prevent spark break down with higher boost applications, check you didnt crack a plug when you did them up, check the primary side of the coils are correctly attached, then if u still have a drama try taping up te tubes and bases of the coils to prevvent the spark going to earth throu those instead of the plug
