#16 (permalink) |
GTR_JED
is enjoying all the new carbon bits
Cars owned: Nissan GTR R35 Titanium, Mercedes CLK Convertible, Audi Q7, Range Rover, VW CC
Where did you buy it from?
#17 (permalink) |
bhp
is not torque
Cars owned: Evo 8
bought off ebay from this user dynamicsounds00
http://www.ebay.co.uk/itm/Dynamat-So...item3f08de2afb
#19 (permalink) |
mickv
is back on Bridgies for summer
Cars owned: R35 DMG Premium
Thinking of having a bash at this myself. I'm a bit of a novice when it comes to this sort of thing though, so may I ask a few questions to those who have already done it? Like:
How much do you need to worry about clearance for refitting the trim - do you need to cut around trim fixings much and presumably the Dynamat is a cm or so thick so clearance potentially an issue? I assume it's self adhesive, but does it stick like superglue or can you tweak it a bit if you make a mess of it? Is it easy to cut? Any other helpful hints? On price, £18.95 a roll is steep compared with the amazon link earlier in this thread - 36 sqft is the same as 9 rolls and 9x18.95 is £170 cf £139 for the bulk pack, so the Amazon link looks like a decent deal. Having said that, if you need more than 9 rolls but less than 18, it might make sense to buy one bulk pack and a few singles. Mick
#20 (permalink) | |
as5606
is missing his GTR
Cars owned: Nissan GTR, Supra TT, 2 x M3 Cab, 335d
Dynamat is only a few mm thick so you shouldn't have any problems with clearance and its SUPER sticky so careful when applying as it will stick to anything. Easyist way to do it is with a "Wife Borrowed" hairdryer to warm it up which makes it mould much easier to the shape of the panel etc.
You don't need to be an*l about how much of the panel you do....doesn't matter if you miss the odd nook and cranny as long as the major surface area is done Quote:
#23 (permalink) |
Anders_R35
is Shells best customer
I'm booking in to Valet Magic for this to help lower road/tyre noise.
MY11 Daytona Blue - GTC Downpipes & Intakes, Whifbitz 4" exhaust, AMS FMIC, ASNU 1100cc Injectors, Ryan G map - 651bhp / 620lbft Alcon 400mm front discs, Alcon 380mm rear discs, Pagid RS29 pads, Castrol SRF Fluid, Carbon bonnet vents, Mines steering wheel |
#24 (permalink) | |
bhp
is not torque
Cars owned: Evo 8
I only did it this way as initially i only bought 5 rolls to just do the rear seat area, but after i was finished i thought it would be wrong to have done so much and then miss out the sides, so ended up having to buy another 3 rolls.
#25 (permalink) |
*MAGIC*
is the UK's finest GTR enhancement specialist.
GTR Register Trader
Its easy to say you only need 1 box but it all depends on how much area you want to cover.
If you do the FULL boot area and FULL rear seat area inc. tunnel then 1 box will not be enough. Robbie
UK's finest GT-R Detailing / Enhancement Specialist. -Creator of the finest GT-R's around - - Studio location - Camberley GU15 - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Tel: 01344 891 891 Direct: 07817 922 095 Oo oO Halo lights available Cobb Accessports available Vinyl Wrapping / Tints / Wheel refurbs. Full bodyshop facilities available Zaino approved detailer Exhausts & Y-Pipes supplied & fitted. Official Knight Racer stockist.
