Making an Electric Pulley - GT-R Register - Official Nissan Skyline and GTR Owners Club forum
Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > Non-Skyline / GT-R chat
Notices
Old 18th October 2003, 06:38 PM   #1 (permalink)
BBD
BBD is unaware they can edit their status
BBD's Avatar
Cars owned: GTR34 Vspec
Send a message via MSN to BBD
Lightbulb Making an Electric Pulley
Sorry dont know where to post this one but here goes.
Is there anyway to make an Electric pulley (on/off Switch) or even better VIA RPM something like the ac compressor pulley but I want to use it for something else.
BBD is offline   Reply With Quote
Old 19th October 2003, 02:35 PM   #2 (permalink)
John Lowe is unaware they can edit their status
John Lowe's Avatar
Cars owned: "Scottie", (Janspeed GTR32), "Mixi" (Sunny GTi-R), and "Suzi", (1300cc Suzuki)
I have no idea what you're talking about, so you'll have to give some more specific information.
12v or 240v?
Draw us a picture and we might come up with some ridiculous suggestions.
John Lowe is offline   Reply With Quote
Old 19th October 2003, 06:58 PM   #3 (permalink)
vennuth is on two wheels
vennuth's Avatar
Cars owned: Integra Type R, CBR 600
Are you going to make your chairs electrically adjustable?
vennuth is offline   Reply With Quote
Old 19th October 2003, 07:06 PM   #4 (permalink)
Hugh Keir is unaware they can edit their status
Hugh Keir's Avatar
Cars owned: R32 GTR Race Car
I smell a supercharger that is linked to an airconditioner pulley that will drop out when the turbos are on boost.
Am I close?
Old 19th October 2003, 11:21 PM   #5 (permalink)
BBD
BBD's Avatar
Actualy Hugh Keir is the closest I have a Vortech V1 Supercharger that is laying around, I checked for space and I cam make it fit instead of the power steering Pump... Loose the power steering and fox the V1 instead.. I however do not want to use it on a manuel pulley that works full time.. I want to make it into a clutch.. a custom bracket and fitting is not a problem I just want to loose the manuel pulley to an electric .. Preffrably at 6-8 PSI and I do not know how to make the conversion.. dont know if its possible..
Old 19th October 2003, 11:34 PM   #6 (permalink)
Hugh Keir's Avatar
I don't know much about air conditioner pulleys, but I believe the shaft is magnetically coupled to the pulley and should only require a power supply through a relay.
There might also be some larger air conditioner pulleys fitted to a bus that might give an improved driving force.
All that would then be required is a system for controlling an external device such as the Motec.
Old 20th October 2003, 05:04 AM   #7 (permalink)
BBD
BBD's Avatar
Stock A/C pulley is alittle big might be good for 3psi if am lucky heheh will open one up see how it goes... I know Motec is the ECU I have to get. Problem I seem to spend my money in other areas right before I have enought for one
Old 20th October 2003, 01:02 PM   #8 (permalink)
323GT-R is unaware they can edit their status
Cars owned: GTR, of sorts...
Air con pumps generally use an electromagnetic clutch to engage them, and this set up has been used in the past in Super-Turbo charged cars, I seem to remember the Koenig Competition, a Ferrari Testarossa with 2 turbos and a supercharger used this set up. If you're after a cheap and cheerful way to test it, why not use a pressure switch in the manifold? The simplest ones are oil pressure switches, An adjustable one would allow you to set a pressure where the supercharger is disabled and the turbos take over...
Sounds like an interesting project...
323GT-R is offline   Reply With Quote
© 2001-2013 Cem Kocu
demoMedia
