#151 (permalink) |
tonigmr2
is rolling rolling rolling
Moderator
You're quite right, I've paid enough to get it undersealed (with the proper stuff) so I shouldn't hammarite odd parts!
I am scratching my head on getting those bushes out, they only press out one way and the other side of the bracket is in the way. Did you manage to do it?
UK R34GTR V-Spec :) Girls drive GTRs too!! |
#152 (permalink) |
Steveline
is [Too Long]
Cars owned: R34 GTR V-SPEC UK --- BMW 740i M-sport
I can email the diagram to you, as i don't have it uploaded!
which bushes are you struggling with?
Build thread: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#153 (permalink) | |
mattysupra
is gutted he sold his R34 GTR S1
Cars owned: R34 GTR OMORI FACTORY SPEC S1
Hi Toni, The rads you can get re-cored. Costs about £40 each. Place in Brum did mine. Sure you will have someone local. As for the suspension arms. Im sure mine was aluminium? Mine would of been Nismo tho. Not sure if that helps?
#154 (permalink) |
Steveline
is [Too Long]
#156 (permalink) |
mattysupra
Also Toni, check all the AF fittings. Mine had corroded and gone brittle with small cracks. I dont think road salt corroded but more caused by two metals reacting. For how simple and maybe £30 in new fittings i would change all the connectors. End of the day if one of those fittings fails the pumps will pump your gearbox dry in a matter of seconds. Its not like it will be a small leek you spot on the garage floor.
#157 (permalink) |
tonigmr2
Moderator
Already on the menu chap. All the fittings are going to be cleaned and inspected, cheers for that though.
At the moment I've got a shell on a dolly and a 1000 parts. It's a bit daunting!
#158 (permalink) | |
mattysupra
I presume you read my rebuild thread? mine went to back to a shell as it was stripped on the outside for a new engine , gearbox, respray all at the same time! Did get very worrying at times when i was stood looking at a very large box of parts and a shell! It will be worth it tho Toni. ![]()
#160 (permalink) | |
Steveline
is [Too Long]
#161 (permalink) |
mattysupra
dont even go there ! I stopped counting. At a guess well over £20k rebuilding mine. Anyway, its sold and gone so end of! ![]()
#162 (permalink) |
tonigmr2
Moderator
I know it's scary.
I suspect this refurb of the shell will be north of £10K and I won't have even started on what I want to do with the engine.That'll have to wait until next year I think! Still, he's a keeper...they're not getting any more common y'know. Just got to count pennies and see if I can afford a bit of bling too now. ![]()
UK R34GTR V-Spec :) Girls drive GTRs too!! Last edited by tonigmr2; 4th April 2012 at 09:21 PM.. |
#163 (permalink) | |
fourtoes
is milk monitor
Bob
Blue 30 TWO............................GTR :) To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Like us on Facebook ZEALOU5 turning cars into heroes. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ZEALOU5 Contact: Bobby Proctor Mobile: 07970699470 Website: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#164 (permalink) |
Clive S-P
is RB26 deficient
Cars owned: GT-R34 V-Spec & Stagea 260RS
Must admit, I thought that too Bob.
I don't think any underseal has been removed though, mine looked just the same. I think Nissan only threatened these cars with underseal tbh!
#165 (permalink) | |
mattysupra
Still we dont know what has exactly taken place. In my case i did mist over brake pipes with satin black. Not sure if this is the case with your car? On my build pics i had similar going on and im surprised no one questioned me. In my case i took pics while paints was wet and like i say it was satin black and not underseal over lines. Again not sure if this is the case on your car?
