8110
Biot Offset Kit bracket question
Hi. I just got my hands on a set of BIOT offset brake kit. This mounts the calipers further out to fit in bigger rotors. I am having issue installing it. Some grinding are required on the knuckle and caliper but that's already all done and works well.
I got everything fitted in but what worries me is that there seems to be a smooth 'ring' on the 2 of the bolts on the bracket. These 2 bolts are bolted on to the knuckle. The other 2 bolts to the calipers have no issues. My concerns are:- 1) Why are there a section of the bolt that is smooth (it's actually a slip on ring)? 2) With the smooth ring, the calipers thus is not fastened to a dead stop. I am able to push it all out to the inside or the outside as per illustration below. Anyone have any idea / expertise on why is the design like so? Pic of the brackets ![]() Pic of the bracket fully depress in ![]() Pic of the bracket fully depress out ![]()
fourtoes
is milk monitor
Looks like your missing some washers/shims to me? Maybe its to allow for correct spacing of the calipers on the rotors with shims?
PM Al, (lightspeed) as he's installed a set of these on his GTR already. Hope that helps. ![]() bob
Blue 30 TWO............................GTR :) To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Like us on Facebook ZEALOU5 turning cars into heroes. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ZEALOU5 Contact: Bobby Proctor Mobile: 07970699470 Website: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
lightspeed
is building an HKS Step 3 2.8 :)
Cars owned: Project BNR32
Are these to fit the R34 N1 rear discs with std rear 33/34 Brembo?
I have some pictures of mine I can post up tonight.
8110
Thanks for the replies.
This is the front kit to convert the rotors to 345mm on a ER34. Would appreciate some pics / input. Else I'm heading to the machine shop to fabricate a stopper ring so that the brackets/calipers would not move as illustrated above.
Marky_GTSt
is a Fire Engine
Cars owned: Skyline GTSt
Yes, looks like it needs shims either side so you can center the caliper on the disc. Putting a spacer on one side only may not be appropriate for correct alignment.
I am Jacks complete lack of surprise. |
